Home > Message Board > Car Audio > Security Systems > Viper alarm problems and how to progr...
Author Thread: Viper alarm problems and how to program remote
vasa
have a viper alarm, it got messed up wouldn't shut off. went to aspen sound and found out that I need new remote bought new remote now don't know how to program it. any help suggestion appreciated
kevind
What model number viper alarm do you have? What is the FCC ID stamped on the back of the remotes?
VASA
fcc id: EZSDEI475
I bought my sister's Accord which came with a viper 300, 2-button remote (red led), circa 1996. My problem is that I hate the fact that it has the passive arm function. Which automatically arms the system after 30 seconds. I'd really prefer to disable it and just manually arm when needed (it is garaged).
I was able to find the manual online, but it didn't say how to to disable this function, just that the technicians program this function if desired. Is there any way I can do this myself? It's driving the wife and I nuts.
Any help would be appreciated. Thanks!
Username: Ps1k0
Post Number: 149
MarvinMan
http://www.directechs.com/guides/manuals/ig/viper/N430V.pdf
start with page 18
VASA
they should all pretty much be the same to program.
open door, key on, press and release the valet switch 9x, then press and hold, the siren should beep 9 times. the press lock on both of your remotes. release the valet switch. key off. test
if it dosen't beep 9x,(does more) then turn the key off and back on and try again.
hope that helps
Username: Ps1k0
Post Number: 150
actually, any authorized viper retailer should beable to code them for you for free. you should be covered under viper warranty for that.
also if it's a decent shop they should have no problem with it.
entTaTee
I had a viper alarm installed about 7 years ago, but since then I have lost both remotes. I disconnected the ground wire on the horn so it doesn't sound and would just mess with the valet button in order to drive it. I have done this for about 2 years now, actually for a year I some how turned the alarm off and didn't have to mess with nothing. But I had a new battery installed 4 months ago and the alarm has been going crazy. It has been messing with my starter, I even had to buy a new starter and just installed it today. Anyways my question is this, is it possible that my alarms brains have gone bad, because it has never acted like this. I know the alarm is supposed to kill the starter, but sometimes I have to take of the positive cable on my battery and put it back on just to get my truck to crank. This problem usually happens if I keep it on Valet mode, but has happened when valet is off. so what should I do, a cheap fix!
I have a viper alarm system model 560XV in my chevy truck, which I purchased used. 20 minutes after I have set the alarm it goes off, the cause of this is the factory radio shutting down. How can this be fixed or bypassed?
Thank You
I just bought a 91 4runner that had a Rattler model 300 alarm system. I somehow turned it off with the remote. how do I reprogram the remote?
the FCC ID is: EZSDEI471
I have a viper 791xv and the remote just stopped working. i tried replacing the battery and still nothing is working. can anyone help me?
vmt
Got my oil changed yesterday. Don't know what the guy did but now my alarm doesn't work & the LED doesn't even light up. What happened?
heatherHH
I have a 3000gt that came with a viper system when i purchased it from a private seller, and the past few days the sensors havent been working (is my guess) like if the system is armed, and i kick a tire or hit the bumper, no sound is made. no sound is made when i arm and disarm either.. any suggestions as to what could be wrong with it and how i can fix it?
please email me if anyone has an answer
hovanitz.1@osu.edu THANK YOU!!
I have a 2002 Mazda Protoge 5 with a 300 series Viper. The remote got salt water inside it and will not function. The valet swith will not function either. Is there a way to disconnect the alarm from the ignition or reprogram it so the valet switch will fuction again?
Note: alarm has been going off randomly about 2x a week for the last 4 or 5 weeks. Could this be a sign of Bad Brains?
FCC ID on remote is: EZSDEI474V
aypsss@gmail.com Thanks.
kaytor
I'm having the exact same problem that Briansmith is having with the exact same system. Anyone else have this problem and know how to fix it?
Username: Ktrader26
Hammond, Indiana
Us
I have a viper alarm I dont know the model but my remotes arent turning it off and the batteries are good in them. We looked for the kill switch but couldnt find one, it was dark out though also. does anyone know where a kill switch would be on a 2002 eclipse? I cant get the car started!!!!!
I bought a 94 Honda Accord that has a Rattler 300 system,I do not have a remote and actually the system is not activated. But, i'm having problems cranking the car. It starts sometimes at random when I open the driver side door. Does anyone have any idea what the problem could be?
I have the 791 XVR and a 2002 PT Cruiser and cant figure out how to program the remote i need help!!! please email me gabe@unknowndesigns.net thank you!
Chad Fremmerlid
I have a viper 500 alarm in my truck. It was working fine, but when I got my tires changed, they also tested my battery. Now I no longer hear the arming chirp and the siren doesn't go off. Only the lights flash. Any help would be greatly appreaciated.
I have a 92 Camaro. When I bought it there was a Viper alarm already installed with a keyless entry. The code on the back of the romote gives the FCC ID as EZSDE1467. I had my car in the shop last week to have the heater core replaced and of course they tore my dash all apart. Now my alarm does not work. It will not set the door locks either. The indicator light is not blinking as it is suppose to do when it is armed. It has juice going to it, but not coming away from it. I cannot find a wiring diagram. Can anyone help? Thanks.
i just bought a 91 honda prelude it has the viper 800esp with the valet 551t remote start but niether one does a darn thing! both status LEDs are blank and my remote has a good battery, my shock sensor still turns red when bumped, any help to get it going WOULD ROCK!!
I just bought a 93 Explorer with a viper alarm system, I'm trying to figure out how to even use it. I don't know what model I have, does any one know how to find out? The number on the back of the remote is FCC ID:EZSDE1467
Username: Sigmachi
Sorry to kind of jump to another topic guys, but I am new at this and need help. I have a viper 791 xv on an Acura 98 TL. Right now, after changing the batteries and all, it cant get it to send signals to my car. I hit the unlock/lock button and it just beeps like it is out of range. I had to manually disable my alarm a few days ago via the vallet switch. What i guess i am asking for help on is how to reprogram my remote to send signals to my car. I am very electronically illeterate so I need MAJOR help. I would appreciate whatever you can do to help. You can email me at schnabel2183@hotmail.com or respond on here. Thanks alot.
Cory
My son has a 92 Tempo bought used with a viper alarm and valet 551t remote start. This is our first experience with this equipment. His battery died & he replaced it. Now he can't start the car because of this security system. It just beeps and disables the starter. We have no books or manuals. How can I disable this so he can use the car again
Barbr
Well its Tuesday and my son's 92 Tempo - Rust and topaz green is still sitting dead on the street. We pushed it back in the drive today. I had a sign on it "steal me if you can". No takers on a 160,000 92 Tempo. Frankly I'm shocked anyone would have bothered even when it was new. Anyway, I've let everyone I know that there is a new important question when buying a used car. Does it have a security system? If so - thats the deal breaker, because no matter what else is going on with the car, if the battery dies that is then end of a running car. Yes, I know, I can pay to tow this dumb thing to some dumb shop who installs these things and pay some ridiculous amount to get rid of it. I only wish the manufacturer of VIPER alarms could read this. There seems to be no real site to get help with the problem. Just pay, pay, pay. Wouldn't it be cheaper to just let someone steal it then collect the insurance money?
I bought an 1995 Toyota Camry and it came with a Viper Alarm EZSDE1485. I can't figure out how to program the remote, but I know the alarm is still on the car because the sensors are noticable and the doors lock automatically when you start the car and unlock when the car is turned off.
Dayron
The battery of my car was dead, after i turn it back on with my friend's car, my viper alarm does not want to work, i press the lock or unlock button, and it doesn't work, it wont let me turn on the car, somebody please help me, i dont know what happen to my alarm.
Help!!!! I bought a jetta which has a Viper alarm system installed. I have no remotes so I have been on vallet mode. The battery in the jetta died and when I try to charge it the alarm goes off. Please, if you have any information that I could use, I would be very greatfull.
Mike Ogle
Correct E-mail address is Jay-rose@comcast.net
I'm just trying to program a 4 button remote control.I think it's the 160XV model. Can anyone help please?
vadarmb
i have a vipe 160xv and the alarm just went crazy and the car won't start. any idea how to bypass this for now?
Username: Ps1k0
Post Number: 232
-Cherokee607123
i have access to alot of viper manuals and maybe able to get you infor to reprogram the remotes, but i'll need to know what model you have.
-Dayron
you also need to reprogram your remotes.
read what i said to Cherokee607123
-Salvatore Garofalo and vadarmb
here's the manual for your alarm, it explains how to re-code the remotes to your alarm.
http://www.directechs.com/guides/manuals/ig/viper/N562V_6-03.pdf
N trouble
please help... i just bought a 2002 sierra gmc truck with a viper system already installed. My remote for it works sometimes and not others. My car alarm sounds off whenever it feels like it or when i hit a bump while I'm driving. It also shuts the car off in the middle if traffic when I'm driving. I've taken it to the dealer they keep telling me to just get anew battery for the remote. I have gotten one and it still will not work. Please if anyone knows how to disarm please tell me before it causes a wreck. thanks.
Username: Ps1k0
Post Number: 242
1st thing, the alarm dosen't shut the car off. It just dosen't work that way. that is a seperate problem all in itself.
your best bet is to take it to an authorized Viper installer (not best Buy) and have them give it the once over to make sure everything is ok. It's possable the brain of the unit has a problem. if so they can send it out for repair.
N trouble
thanks for your advice. However, I took my car to a electrician shop who installs viper systems in town, turns out the viper system was shutting off my car when the alarm was sounding off while i was driving, it is part of the saftey system if your car gets stolen. The system was initially put/wired into the car wrong so i just had him remove it, my life isn't worth a faulty system. Thanks a bunch for your advice.
Username: Psycoj
Joliet, Il
U.s
just out of curiousity did you see if your car needed an immobilezer to bypass the security in your sirra N trouble
N trouble
Juan, I have no ideal what that is but no. I just told the electrician to take it out. do you think that would have helped. I'm thinking about getting a newer version.
Hello, I have a viper alarm and the remote is old. It is a RPN 471T with an FCC ID of EZSDE1471. I need to program a new one. Can anyone post the instructions?
I have a viper alarm 671xv which for some reason is set and the remote will not unlock. by pushing the lock or unlock buttons nothing happens. I managed to use the valet to turn the alarm off so i could start vehicle, how do i re-program the alarm
I have a 791vx and recently it no longer sounds on remote or vibrates when alarm is activated. this feature use to work. I guess you would call it the responder feature. All other features work RS, Doorlocks lock and unlock etc.. just the paging when alarm activated.... Thanks
acruz@knology.net with any help
I have a 1995 Honda Accord, and we have just installed the Viper 160xv. Everything seems to work, except the power door locks will not activate from the remote. The horn and lights function when trying to unlock/lock the doors, but the doors won't work. We have located the car's lock/unlock wires, but no matter which wires from the Viper that we hook up, still it won't work. There are five wires coming from the door unlock relay. Which should we use? Any help would be appreciated.
Username: Ps1k0
Nudi$t Colony, Woo Hoo
Post Number: 253
wiring diagrams can be found at www.bulldogsecurity.com for the umpte-thousandth time. look there and it will tell you all you need to know
sqwedg
Yes, we had the diagram when we installed the unit, and we have located the wires on the car. The lock and unlock both activate when probing these wires with a wire hooked to ground. There are five wires on the Viper unit; and the instructions don't tell which ones to use (obviously all five couldn't be used!) We tried every combination possible, and nothing worked. When pressing the remote, we can hear the relay in the Viper 160xv door lock/unlock module clicking, but can measure no output on any of the wires. I hope all this makes sense and someone can help us. Thanks so much!
Have an older 'from 2000' model viper alarm w/ remote start. Ever since i got a replacement remote i couldnt figure out how to program the remote start to work. I did find one of the original remotes too. its a ezsdei475. any help?
KenTDH18
My VIPER alarm doesnt respond to my remote, it beeps like it is out of range. I cant start my car because of it. My car was sitting still for one month while I was on vacation but the radio, lights, and alarm all work so the battery isnt dead. How can I fix this problem?
Re: 95 Accord - doorlocks
The car wires should be BLACK WITH A WHITE STRIPE for lock, and ORANGE for unlock. Be sure they test before conencting to them.
Are your 5 wires green, blue, white, brown, and purple? If yes:
There should just be a small 3-pin plug with 2 wires coming out of it (blue and green) as part of the remote start package. Use that instead of the little box with the connector to the unit. (That little box is a 451M)
The blue will be unlock and the green will be lock.
They can be changed from a negative pulse (which is what your vehicle needs, and is also the default) to a positive one.
It may either be a jumper, programmed, or having a different wired tied to either 12v or Gnd. I'm sorry I can't be more specific, it's not a model we carry anymore and I don't have the installation guide for it. But, if you haven't changed any of those things, then don't worry about it.
Also, if you've lost that other piece or it was missing (It's just a tiny cream colored plug with two thin wires coming out of it), you can use the 451M, just connect the purple wire to ground and use blue as your unlock, green as your lock, and chop the other 2.
It would figure, right after my post, I find a manual for the 160XV.
On this model, simply reversing the blue & green wires would work for vehicles with a positive triggered locking. But you don't need to worry about this.
Also, since this is an "older" car, I recommend running the tach wire, you can use voltage if you want, but tach is more reliable.
Trying2BHelpful
Ken - It sounds like the battery in your remote may be going. Try a new battery in it and see if that helps. If not, it may have lost it's programming.
JL
Hey everyone, I have an EZSDEI475 system on a Toyota Camry and it has BOTH a cutoff switch and button. The vehicle also has a factory Toyota system.
My problem: When the car gets cold and I attempt to remote start it, it will not crank enough. Like on all cars, if the start up time on a warm engine is 1.2 seconds, on a cold car it may be anywhere from 2 seconds to 3 seconds. It has something to do with anti-grind. I just need to know how to adjust the anti-grind so that it realizes that it needs to hold down the starter just a little longer until it turns over.
On a starting try, it will start and if the turnover doesn't occur, it will stop and then retry 2 more times and if that doesn't work, it will cut off but the lights will remain on (also need to know how to shut the lights off remotely).
Another thing, on a remote start, the clock and radio will not get power while remote started whereas the windshield wipers, heat, and windows WILL work.
Please advise.
Thank you
Actually, it has nothing to do with anti-grind. Anti-grind simply prevents the starter from grinding when you put the key in and turn it too far after remote starting.
There's a setting through the programming called "crank time".
Do you know the model of the remote start? IE: Python, Valet, Viper, etc? I couldn't find any DEI products in my system that are "475"s.
It's usually option 5.
Also, it seems as though someone didn't hook up the second accessory wire from the remote start to the car. In some vehicles this connection isn't needed to perform the starting. If you give me the year of your car, I can tell you which wire it is.
-Dave
And that cutoff switch, is a neutral safety switch. Switching it to the "off" position will disable the remote start features.
The button is what you use to enter the menus, put the system in valet mode, etc. Don't mess with it unless you know what you're doing.
If you have anti-grind, it's probably a higher-end model, which means it's probably menu 2, option 5.
j0n
I just bought another remote for my car. It's a FCC ID: EZSDEI467 , but I don't know how to program it. Can anyone help me out here? I only have one functional remote and I don't know how much longer it's going to last. Any help would be great! Thanks in advance.
Username: Pausa
Glasgow, Scotland
Scotland
Can anyone help i have a viper alarm on my car which was bypassed manually as i was awaiting new remote now i dont have a clue how to connect it again.... tried taking it to a car electrical place and they did not have a clue???
j0n: What model Viper system is in your car? Please give me the name, instead of the FCC ID. Thx.
Pauline: That's a tough one. They could have put the alarm in Valet mode, or they could have just cut power to it, or they could have just unplugged the main harness. Is your LED (the tiny alarm light) lit constantly, or do you never see it lit? If the unit was installed well, finding it to reconnect it should be a very difficult task. It depends on how well the wires and brain were hidden.
j0n
honestly im not sure what model the system is. i bought my car with the alarm already installed. but i do have a picture of it if it helps at all.
http://i17.photobucket.com/albums/b72/j0nathanL3e/Random%20Shizzle/viperalarm2.j pg
Username: Pausa
Glasgow, Scotland
Scotland
the led is off constantly even when i press the "black button" nothing happens sdpoke with viper and they told me how to reset it then realised it had be manually bypassed i can see some wire near the led and it looks like black tape around some of the wires???? the model on back of phobe is FCC ID:EZSDE1487
Oodlez
I have a Python 476P remote for a 1991 Honda Accord. I don't know how to program it. The FCC ID is EZSDEI475. Can someone plese give me instructions on how to program it?
j0n- A lot of Viper alarms use the same remotes. If you can find a site that can get you the model name & number of the unit itself based off the FCC ID on the box or something, I can be more help.
Pauline- It's common practice to wrap black tape around all the wires when installing an alarm. This helps to disguise the alarm to look more like factory wires, thus making it harder for a thief to bypass.
Try this: Put the key in the ignition. Turn it to the 'on' position, but not so far that it starts, then within 5 seconds push and hold the black button, and keep your eye on the LED. If it blinks, you shouldn't have to worry about any wire connections. Then release the button.
You can also try taking it to your local Circuit City or Best Buy. Explain that it was installed for you as a gift, so you're not exactly sure where it was installed, but you think it was there. Your best bet is to find a time when they're not busy. It also won't hurt if the manager is in a good mood, so be real nice, and if they have the time, they'll usually at least take a look under the dash for you.
BTW- The model you have is one their better ones.
Oodlez- If you can get me the model name & number of the actual unit I can tell you how to program it.
Wish I could be more help, evryone.
Try this: Put the key in the ignition. Turn it to the 'on' position, but not so far that it starts, then turn it back and remove it, then within 5 seconds push and hold the black button, and keep your eye on the LED. If it blinks, you shouldn't have to worry about any wire connections. Then release the button.
Username: Alybre
I have a Viper 478 VP/C that is not working. When I push any button all I get is 3 beeps and an ant. with tx appears in the upper lft. corner of display. When I put a fresh battery in it the sensors appear and makes sounds like it always did but does nothing else. It does show that my car is unlocked. Any help?
Username: Alybre
Sorry- My remote beeps 4 times and it shows that doors are unlocked but they aren't.
j0n
Alright I finally figured out the model. It's a 492T. I hope this is enough for you to work with. Thanks in advance
ok, j0n, I think I got it. That's the remote model number, not the actual unit, but try these steps and see if it works.
Step 1: Open a door. (a car door... your car ;) )
Step 2: Put the key in the ignition and turn it to the "Run" position.
Step 3: Push & release the program button (the black button in your car - usually located under dash or driver's kick panel) once and then release.
Step 4: Push & hold the program button in (keep holding).
(Unit -should- chirp once)
Step 5: Press and release a button on your remote (this button will be your arm/disarm button)
Step 6: Release the program button.
Step 7: Press & Release the program button.
Step 8: Press & Hold the program button (do not release).
(unit should chirp twice)
Step 9: Press button2 (or the other button) on your remote.
Step 10: Release program button.
Step 11: Turn key off.
(Unit should emit a long chirp to confirm)
Let me know how it works.
-Dave
P.S. You can make Button 1 arm/disarm or button 2, just press the other button in Step 9.
P.P.S. Taking too long between steps will cause the unti to exit learn routine.
JL reply
AutoDave,
My Camry is an '03 LE without auto lights. What I'm able to do is leave the headlights or high beams on and then they will shut off when I press lock on the factory remote twice, not the DEI remote. Is there a way to get it to do this? Also, when I press lock and unlock the lights do not flash??
I don't know the model of the system, I just know that the fcc id # is EZSDEI475 if that helps.
Is there a way to get a manual of all the different programming functions possible?
Am I able to elimate the DEI remote altogether and just setup the factory remote so that it works in tandem with the DEI system? A client of mine had a system in an '02 Yukon where he would press lock twice on the factory gm remote and it would remote start the truck via an aftermarket system, is there a way to do this on mine?
Username: Sportybabe
Woodinville, WA
Someone please help me figure out what is wrong with my Viper 791xv alarm all of the sudden the screen on the transmitter stopped showing what my car was doing but the car still did what i said. For example i will unlock my car and it will unlock but it will show it as locked. And the transmitter beeps six times...can anyone please help me with this problem!?
Username: Pausa
Glasgow, Scotland
Scotland
AutoDave i have had a little bit luck i have got the led on now think my remote needs programme as it aint responding can u help???? cant take it to anywhere in the us as im in scotland lol thanks for the previous help m8
faithmm
I have a viper 791xv that will not disable. I do not know what happened, I went to work for eight hours and then tried to start my vehicle from my remote and it kept telling me that it was out of range, then I tried to unlock and disarm my vehicle and it still beeps that it is out of range. I have tried the valet button, but I must be using it wrong or something because after pressing the button nothing happens, except the alarm goes off and my vehicle's kill switch is activated. I do not remember discussing the valet mode with my installer though. HELP, my vehicle is stuck in a parking lot and is completely disabled. I have gone on line with viper, but all that is is them trying to sell me something.
JL,
There should be a way to set up the DEI remotes to shut off the lights, but it may require running another wire & some programming.
I'll look into getting the factory remotes to work with the DEI product - I haven't done much of that myself.
Do any lights respond to your remote? If not, either the wire wasn't hooked up from the unit to the car, or the inline fuse for the parking light wire needs to be replaced.
Unfortunately, without the actual model or FCC ID of the unit (not the remote) I can't get a list of programming options for you.
Pauline:
Just drive on over to NY and I'll fix it. Just remember to keep your windows rolled up during the drive and don't forget to take a left at the giant squid.
The LED is solid now, correct? This means the unit is in Valet mode. To get out of it, turn the key to the "on" position then back off, and just press the black button in the car again.
You can then program the remote, use the process I outlined to j0n in my 1.26 post, but go straight to Step 11 after Step 6 (and you can use any button on the remote and it will learn the default configuration).
faithmm,
You can get into Valet mode the same way you get out of it (see my last post). Turn key on. Turn key off. Push button. LED will go on if entering Valet mode, and go out if exiting Valet mode.
You can also use the instructions for Pauline for programming the remote. (it sounds like your remote may have lost it's programming)
Chelsea,
It sounds like your transmitter may have taken a crap. You can try reprogramming it, but I'm not sure that will help.
Woodinville, WA
AutoDave-
thanks for the help iam taking it to best buy either tomorrow or saturday...this sucks cause i just bought it like 3 months ago and havent gotten it wet or dropped so ill be pissed if it doesnt work anymore
JL reply
AutoDave,
I'll look for an fcc unit id. I'm guessing that its probably on the 'brain' of the system which I'm also guessing is probably somewhere under the dash.
The way the setup is now, I don't have auto lights on the Camry but if I leave the lights on and press lock on the factory remote, the lights will shut off - not the case with the DEI remote. Upon a remote start, those lights that were left on will then turn back on.
But if you could find a way to have the factory remote control the DEI system, that would be phenominal. This setup would have to modify the factory remote so that it would lock and unlock the vehicle while the ignition is on.
I will reply back as soon as I find the unit id.
Thanks AutoDave.
JL
i have a 1500 hp civic si. any one wanna race? im up to it!!! for pinks too
Dave552
Hey autodave, I just realized that I bought my used car with a valet 552T which is similar to the viper I guess. So I just bought a 471T remote from ebay b/c the date code is 9J. I tried to program it using your instructions but I get no chirps or anything. I just put in a switch on the blue terminals too.
Dave552
I have a 1992 Pontiac Grand Prix I lost my remote and now i am unable to start my car as the alarm system is activated and i cannot disarm it. Is there a shutoff switch somewhere in the car to disarm the alarm system. Please help as my car has been parked for 2 weeks
JL reply
Anonymous, like most alarms, assuming that it is a normal alarm, there should be a cutoff switch or button somewhere under the dashboard on the driver's side. Once the alarm is ringing, turn the key to the on position and then press the button or flick the switch-which ever you have.
Autodave,
Any info on getting the Toyota remote to control the remote start? Still working on getting that model number off of the box.
Mustang-5-0
i have a viper alarm model 800 that does not respond to my remote (which has a good battery), yet sometimes the starter-kill prevents me from starting the car... I have a valet switch (not a pushbutton), and an LED light. I also have a random black wire coming from the brain of the alarm that I found hidden under the dash and have no idea what it is for.
Does anyone know why the remote is not working, and how I can get it to control the alarm/doorlocks again? Thanks.
I bought a 1995 jetta used and it has an alarm installed but unhooked. I am not sure what type it is but the brain has an fcc id on it. EZSDEI4530-A it says its a directed electronics there is a white sticker that has ok/5A on it and a white sticker that has 330381A on it. Can someone tell me what kind of alarm it is and if I can get a replacement remote for it??
Username: Novice73
have a viper 560 xv... i accidentally set the permanent silent mode on (don't know how)... how do i deactivate this feature (not in the manual) ... also want to know how to program the unit for passive arming ... thanks
Jero
Hi all,
Just letting you know that I followed Ps1k0's instructions and they worked a treat. However, with mine, I only required 7 presses of the valet (+ the 8th press-and-hold).
So if 9 presses doesn't work, try a different number of presses :-)
Thanks a bunch for your help, Ps1k0.
Username: Carcrzyqt
Fort Washington, MD
USa
I have a 1997 Mitsubishi Eclipse my ex-boyfriend lost the only remote I had for my viper alarm. It has an ignition cut off and the battery died when I try to jump the battery the alarm goes off. I need to know how I can turn it off til I can get a new remote made. Any ideas?
Username: Boutinma
I have an old Viper 800HF, my remote quit and I got a new one (476T FC: EZSDEI475) but it didn't come with instructions for programming it to the car.
Could anyone help me? Thanks! (loci@hotmail.com)
Username: Schroerj
I have a viper 560xv that was in my 02 Buick LeSabre when it was purchased used... Haven't had any probs with it for 4 months, but my sister borrowed the car the other night and I guess her boyfriend tried to open the door right after she armed the alarm (she claims that's when the led came on and stayed on)... now the LED is on constantly and the alarm doesn't arm. The locks still work, panic still works, remote start still works. I don't know where the valet/program/disable switches are since the system was already installed when I bought the car. I've felt around everywhere to see if i could find them. Any help would be greatly appreciated. -Jay
Username: Rhinoh22
Clovis, CA
Hey Ps1k0,
My 350HV wont respond to the remotes, used your, key on, valet 9x trick. It beeped 9 times after holding button, then siren wailed for a sec after I turned the key off. It still wouldnt respond.
My original problem was this:
The remotes just stopped working, changed the battery and they still didnt work. Got off work and they started working for a day or 2. Stopped for a day, then today, worked once. (lock/unlock) now I cant get it to respond to the remotes. Help! How do I find a authorized Viper dealer in my area?
Thanx in advance.
Username: Alkh3m15t
I have the Viper 791xv, FCC ID:EZSDEI478. About a week ago, my car alarm lights wouldn't blink when I arm and disarm but it still works. Could it be the fuse or something? Although, when the alarm does go off, the lights blink. And my remote is also acting funny. When the alarm goes off, it'll show the icon of the horn instead of paging me with the beep like it used to. Can anyone help me out with getting the lights to blink again and the paging to beep. Is it on a silent mode or something, how can I return it to default settings? Thanks. alkh3m15t@yahoo.com
Username: Rantz
Does anyone know some information on the symbols that appear on the screen. Mine has 3 vertical wave marks little under the bottom of the car on the screen. and i cannot figure out why or what this means.
Username: Godofdeth2002
need to know if i can pull the wires to the alarm and the car still run?
Username: Rantz
yes if you unhook the brain the car will run
Username: Dice231
I need some help with finding the manual for FCC ID: EZDEI471 ... if anyone can help that would be great
Username: Mish
I have a viper 791XV i have the installation guide but i am looking for the other guide that came with it i seem to have lost mine. Does anyone know where i would be able to get one from?
Username: Ellynsker
Ok, so i have this viper alarm on my vet and its an older alarm i need programing codes for the remote so the alarm wont go haywire! Can someone help me?. this is the code on the back.
FCC ID:EZSDEI494
Username: Miker1701
I have a black four button remote which has lost its code. The remote has four buttons labelled I,II,III and IV. I do not know what system I have other than it is a Viper. Can you help?
Thanks, MikeR1701
Username: Bunniesrsick
hows it going to you all . i bougt a car not to long ago that has a viper 600. the alarm works but i cant arm it. if i holl the button on the remote the alarm will go off and if i press it again it will disarm. does any one have a maual for a viper 600 or can some one help me solve this problem. i think that the remote just needs to be reprogamed, i have no idea how to do this. thanks
Username: Lantz320
Need help, the car won't start.
I had a battery installed in our recently inherited Honda Accord. A new battery was also put in the remote control. The kill switch in the car is broken. Is there a code that can be input in order to start the car? Thanks Symba
Username: Lantz320
Sorry, it is a Viper
Alarm SYSTEM this is inscribed on the back of the remote: 68 billion codes 800-274-0200, DEI 333.634 FCC# EZ8DE1491. Thanks Symba
Username: Zcruiser
NC
Autodave - I looked in here because I'm having problems with a 350HV, but after reading your posts I think I'll be able to fix it and be happy again.
So.... THANKS!
z
Username: Mindyurownbusnis
i have a viper 791xv alarm. i had it installed a month or so ago. I just had to replace my car battery and now when i use the remote start to strt the vehicle it cranks up but then immediately dies, but i can start my car with the key. Also the transmitter screen does not show the correct actions, i can send a signal to unlock my car, and the doors will unlock but the screen still shows a lock. any suggestions?
Username: Sheba1985
I have a Viper 160XV installed in a 2004 Honda Odyssey. The range of the remote start used to be fantastic. Now it only starts if I am standing right next to the car. I replaced the battery in the remote and the range is still very poor. Is there a battery in the unit that needs to be replaced? Or, is there some other problem. Thanks for your help!!
Username: Stormadj1
Autodave- I bought a tahoe the other day, and it has a functioning alarm, problem is I only have one remote and I have no idea what this thing is or where it was purchased. The FCC ID is QNMSK1027. What is this thing and where can I get information on it?
Username: Ricanjaydakiss
Eatontown, New jersey
Usa
I have a problem, i bought a viper 791xv, and installed it myself(not really, my friend did it), and i have on little issue, i lost the wiring harness for the starter kill and door lock, dont ask me how, but i did, it was a small harness, maybe 3 or 4 wires out of it. i need help finding out how i can get a hold of this harness, i really dont wanna go through dei cause i wanna register it, and yes i know a way to register it without getting it professionally installed and still be warrantied. thank you in advance whoever can help me
Username: Sandy79
I AM SURE YOU HAVE ANSWERED THIS QUESTION BEFORE BUT I NEED HELP I WANT TO KNOW HOW TO MAKE MY LIGHTS FLASH WHEN TURNING ON OR OFF THE ALARM I'VE DONE IT BEFORE BUT I DON'T KNOW HOW CAN YOU HELP ME PLEASE
Username: Rastarossen
Hello everyone,
I spent a day reading through the forum and trying to figure out what to do. As a result, now I know that my car has a Viper C50 alarm which unfortunatelly malfunctioned yesterday. Now my car is in the parking lot and I can't start it. I tried locating a valet switch, but I only found the connector and the wires coming out of it (2blue connector) at the end there is no switch. The remote itself still blinks red and I do not know if it's working or not? The alarm does not respond when I press it. I disconected the car battery thinnking that this might reset the system and as you probably know it did and now I would not shut up :-(. So i disconnected the battery. I am trying to find an installation manual. Do you guys know if the valet switch is a simple one. Meaning if i short the two wires after having the key in on/off position will that disable the alarm? is there a hardware way to do it, will the car work if I plug out the braker on the 12v wire of the brain itself? any input is appreciated, i was supposed to drive to chicago today and I can't so I am really in the deep...
Username: Uruser2001
I have a Ford, Econoline 94' and it is not working...I thought that maybe it was the viper alarm problem ID:EZSDE1437 because the alarm didn't turn off when I pressed the buttom of the remote..I disconected the viper and the car has not always current...I am not sure what the problem is..is there any posibilities that the problem is the alarm?? If anyone knew please write to me to my e-mail address uruser2001@yahoo.es any help will be really useful. Thanks, Sergio.
Username: Tikity
I have a Viper 600 HF. My car won't start. I think it is the starter kill on the alarm. I have tried to use the learn routine to turn off the engine immobilizer, that didn't work. The owners guide says there is an emergency override, does anyone know what that is or know how to get my car to start again?
Username: Suzannesanderson
Viper 135HF
I lost the remote - bought a new one off ebay
How do I program it?
Username: Rick_ross
Post Number: 288
read the instructions
I lost my manual
Username: Utopiasociety
New Orleans, LA
US
I just bought a new vehicle and the sales person knew nothing about this Viper alarm and it came with absolutely no instructions. The alarm automatically sets itself after a few seconds and he knew nothing about the auto start. Can anyone help me with this? It is a RPN 479V/P/C, FCC ID #EZSDE1478.
Username: Kgirdner
Wetumpka, AL
United States
Hello can anyone tell me how to program a Viper a 479 VP/C ? THANKS
Username: Eviscerator
Apparently my post was lost in cyberspace :-(
Hello,
I don't know how to see or retrieve my 1st post that shows on my post count but is somehow gone. So here is a smaller version of my original request for help.
I have a Viper alarm with remote start. The key fob is a RPN 476V
the other codes on the back are as follows;
2(66) Codes
FCC ID# EZSDEi476
I need a source for an online manual since mine did not come with one so as to program a second remote.
Thanks for any help or advice you may be able to provide.
Username: Chevy_man_9605
I have a "96 beretta with a viper alarm. I need to know what type of viper alarm I have. I also need to know how to get a new remote. The FCC ID number on my current remote is EZSDEI490. I also need to know if there is a way to make the remote I have work better, it only works when it wants to. PLEASE HELP!!!!
Username: Toohotty
I have a Viper 350 alarm. Awhile ago my remote went bad. Then, I had to have a new clutch installed. I am sure that they disconnected the battery when they did it. When I bought a new remote, I tried programming it using instructions from this site, but it didn't work. I also took it to Best Buy where they install the same alarm, but they could not figure out how to program the remote either. I have moved since it was installed, so I can't take it back to where I got it. Now, my car keeps locking and unlocking all the time. So I have an alarm that doesn't do my any good, and my car keeps locking and unlocking as I drive, which is annoying and frightening. Any help would be greatly appreciate. Thank you
Username: W_sr
Hi,
I bought a car with a viper alarm that cam with no instrucitons.
Can anyone tell me how to check the model using the FCC ID?
Also, one of the door doesnt work with the keyless entry. can anyone tell me how to resolve this?
thanks
my email is w_sr1983@yahoo.com.sg
Username: Christina2006
Hi, i jus bought a 1996 toyota corolla and i am not use to the automatic alarm. i dont like how it just turn on by itself. The alarm going off drives me crazy and i want to switch to manual. Can anyone give me instructions on how to switch the alarm to manual. My FCC ID is EZSDEI467. i really appreciate if you guys can help me. thank you.
my email is saephan06@yahoo.com
Username: Floatfisher
Chicago, IL
Hello to everybody. Please help me. I bought a 2002 Toyota Corolla S with VIPER 560XV installed. I woul like to activate some features. I need Programing Guide. Please help me. Thank you very much.
Username: Ps1k0
Post Number: 263
http://www.directechs.com/guides/manuals/ig/viper/N563V_6-03.pdf
here you go
Chicago, IL
Ps1k0, thank you very much fest response. Thanks once again.
Username: 4play_pinoy
i got a viper ultra 700HF and i diconnected the batt. and all of the sudden my 4 button remote stop working. please help me reprogram my remote. on the back of my remote it says DEI 68 BILLION CODES......FCC ID EZSDEI485
Username: Kingjimmy
I need help guys... I have a viper alarm, not sure what model.
FCC ID: EZSDE1478.
Heres the problem. My remote will not lock or unlock my car. Whenever i press the button to unlock or lock the car, the remotes chirps as if i am out of range or without reception. Does anyone know what the problem could be?
Username: Wjlane
Bought a '95 Sable and found a Rattler 300 main unit under the dash today. However, the siren, LED indicator and the valet switch are all missing. The door locks function and are the only thing still connected to the main unit. I don't have a remote either. Can I buy a replacement transmitter and somehow still use it for keyless entry? How would I program it?
Username: Chopnitup
Toronto, Ontario
Ps1k0, could you please post the manual(s) for the Viper 5000, and possibly for the 489V remote if there is one, much appreciated.
And if someone could let me know where the best place to buy replacement remotes from, either Best Buy, Future Shop, etc.. or and authorized dealer. BTW I am in Toronto, Canada
Username: Hulksmash
Ny, Ny
Usa
can anyone tell me how to program a viper remote
fcc#ezsdeI475 thank you
Username: Wacebiglosone
Rockville, Md
Us
I GOT A 1990 LINCOLN TOWN CAR AND I WANTED TO INSTALL A VIPER 790XV. BEFORE I WAS GOING TO GET IT INSTALLED THE OLD REMOTE {RPN478V/P/C EZSDEI478} BROKE AND DIDNT TURN ON ANYMORE, SO I ORDER A NEW REMOTE(479V/P/XEZSDEI4780),IS THERE A SPECIAL WAY TO PROGRAM THE NEW REMOTE IF I DONT HAVE THE OLD ONE?ALSO I CONNECTED ALL THE BASIC WIRING TO MY CAR(LED,POWER,GROUND,ANT,AND SIERENS, CAN SOMEONE HELP ME WITH THE REST?(((RELAYS)))),(DOORLOCKS,TRUNK UNLOCK,IGNTION WIRES AND REMOTE START) IS THERE ANYTHING I NEED TO KNOW BEFORE TRYING TO CONNECT ANY OF THESE THINGS? LIKE WHAT NOT TO DO. PLEASE HELP,IM LOST!
Username: Dmarta
I am looking for an installation manual for a viper 571xv
Username: Hondalynne
hello- thank you in advance for any help you can offer.
I have a 97 honda accord wagon with an aftermarket alarm-I purchased the car used. i have no idea what kind of alarm is in it. what i do know is my remote is and Automate: FCC ID: ezsdei467.
I want the alarm disarmed. my remote works inconsistently (new battery) and i am forced to enter the car with the alarm going off and insert the key and manually turn off the alarm with the valet switch. sometimes i get it right quickly others i dont. its very frustrating. this is my only working remote since no one seems to know how to program the other one i have (i have asked many a mechanic).
however, i just want it off. it was off for 6 months as i had my car shipped and they woouldnt ship it with the alarm activated so SOMEONE figured it out (sadly i dont know who or how). when my starter went the other week, they replaced the starter and battery and now of course the alarm works again.
can anyone help? i just want to know how to disable the alarm.
thanks so much.
Username: Xziler8r
I also have a 791XV Alarm on a 00 Sebring. I cleaned my battery terminals on my car, and ever since my remote won't respond to the system at all. I tried the 12 step process listed above, as well as pressing LOCK on the remote multiple times to re-sync the remote, but nothing's working at all. I dont get a chirp when pressing the black button in the car once and then press and hold. Can anyone help me further troubleshoot this?
Username: Njtrooper
NEED HELP!
I have a Viper car alarm and I do not have the manual to reprogram. The id code on the back of the remote is:
FCC ID: EZSDE1467
Problem 1:
My alarm does not make noise anymore. Everything is silent. I would like it to make noise with the alarm is triggered.
Problem 2:
The alarm is not locking the doors when I push the button on the remote, but when I unlock the doors with the remote it unlocks the doors.
Please HELP!
Thanks
Username: Martinzz22
i need help i have a viper 790xv installed in my 98 corolla, recently i lost the transmitter for it, purchased a new one the 479v transmitter, tried to program it and would only work for one button, the lock and unlock mode would only work for one button only, wouldnt learn all 4 buttons. please help
Username: Dave111
Can anyone help with a wiring diagram for a viper 480xv. Thanks
Username: Alen87
Melbourne, VIC
Australia
i have a EZSDEI472 viper alarm, and i have lost the frequency between the alarm and the remote, how to do re-conect it? i took off the bottom part of the dash and have found this little thing with a red light flashing and a button, i assume it has to do something with the alarm because it this guy once re-conected it for me before and he did something around that area but cant remeber what.
Username: Petermx5
Christchurch, NZ
My Viper 700 alarm has started constantly locking, then unlocking the car while it is sitting idle. The lock is just the normal passive lock sequence. But why on earth does it then immediately (typically 1 to 10 seconds later, a bit random) UNLOCK it?
The unlock also happens when I manually lock it. Wasn't doing it yesterday, but I do suspect it's had this behaviour on *occasion* since I got the car (with the alarm pre-fitted).
For now, it's in valet mode and all is fine if I'm prepared to leave it unlocked. But apart from waiting for it to fix itself, any suggestions for a longer-term fix?
Username: Petermx5
Christchurch, NZ
Well, I see answers are rare here, so I recommend you go to http://www.allexperts.com -- I asked the same question there and had a result in under a day. They recommended checking the ground wire of the "brain" -- apparently poor grounding/connections is the root cause of almost all "random" behaviour.
While I was attempting to find that (not at all easy in an MX5!) I found a spade fuse in the circuit that was loose. Fixed it, problem went away. Now THAT's helpful!
Username: Pearltt
Can anyone send me a link for the install guide for a viper 790xv. I am trying to reprogram the remotes and I need to know how many times i need to press the valet switch in order to program each channel(lock, unlock,remote start...etc). I tried using the one for the 791xv but i think it's different. Thanks
Username: F350_spanky
Kck, Ks
i have a ezsdei476 it works geat for 6 years then goes nuts and wont do anything changed the battery in the remote still nothing cant find the program button.
it would be greatly appriceated for a reply
thank u
Username: Iiileonardiii
NJ
How can the remote be programmed for the remote start function on the 791xv model?
Username: Jflexo
Coopersburg, PA
I have a Viper 3000, it's great, but I think it is draining down my battery if the van sits for 3 or more days. I tied to find out how many amps it draws when activated, but it's not in the manual and I can't find it w/Google. Any sugggestions? Thx!
Username: Kraze1996
I have an old Viper system which needs a new remote programmed to it. I brought the car to the dealer who installed the system many years ago and they did not know how to program the remote. Any suggestions?
Username: Naldo789
i got a viper 560 in a 1500 sierra pick up and the trasmisson silonods burn out in had the alarm remote/starte 4 1 day can any 1 help
Username: Navywife
Glen Burnie , Maryland
I just bought a 2003 trailblazer and it had a viper 560XV already installed but the remotes will not work does anyone know how to program them please email me Harrison92303@aol.com
Username: Nine11man
Tampa, Fl
have a viper alarm red light in dash stays lit all time, doesnt flash
Alarm doenst chirp anymore either
is there a series of buttoms onthe remote I press to reset the system to normal (chirp on & off & flashing dash light)
codes on back RPN47IT
FCC ID EZSDE1471
Looks like a DEI brand?
email me at nine11man@yaoo.com
Username: Damom
I just want to disable my viper .
I have no idea what the wires look like or how to go about it
any simple fix?
the car is old , the key chain transmitter wont work even with a new battery, i just dont want to deal with it any more.
any idea?
can i just pull a fuse?
how would i know which one?
Kck, Ks
if u can find the viper box under the dash there is a 12 or 13 wire harness. there sould be a red wire coming out and going into a fuse. if u pull it no mo power
Username: Rescue450
Roanoke Rapids, NC
Usa
need help with programming a remote.FCC ID EZSDEI485
Username: Dravi
Dearborn, MI
Hello,
I Have one Python FCC ID : EZSDE1478 keyless entry (with four buttons, Lock, Unlock, Aux, *) fitted to my Honda Accord 1999 Model. I purchased this car a week back. Yesterday keyless started entry suddenly stopped working. If you remove and insert the battery in it showing everything properly. But unable to car doors with this key. So tried to open manually but car's theft alram started ringing. I tried to start engine also but I was unsuccessful and steering got locked. So Can anybody reply to message How to unlock my car?
Thanks
Ravi
Username: Lisal
Hello,
I just got a 1998 legend and it has the Python 1500hf in it. I got 2 remotes with it and they seem to be working. The problem is that I did not get any instructions or books for the Python system. My brother actually looked under the dash and confirmed the model number.
The remotes need to be reprogrammed because they are not communicating with the unit. I got on http://www.directed.com/ to get the manual but they only list the user manual and has nothing in it to program the remotes.
Hope some good soul would let me know the procedure to do that. It is driving me crazy, locking doors and sounding alarms randomly. Thank you in advance
Lisa
Username: Ryan_10
Vincent, Oh
Usa
i have a 95 jeep grand cherokee with the viper 560XV remote start/ alarm system. my problem is that everything works except the power locks, when i hit the button they will not lock or unlock but everything else works fine. your suggestions or answers would very appreciated. put them on here or my email is ryan_10_smith@yahoo.com thanks...
Username: Farmerbobb86
I have a Viper 479V Alarm. FCC ID: EZSDEI478.
All of the sudden my remote/alarm started acting weird. Whenever I press the Lock button the alarm arms and the doors lock, but the remote beeps saying that it has to signal and the picture of the lock stays unlocked even though it is armed. Every 5 seconds the little antenna with RX next to it will flash. I am right next to the car, it can't be something with range.
Has anyone had this problem or does anyone know what is wrong with my alarm?
Rantz Maxson: The 3 vertical wave lines means "vibrate" as opposed to the beep the alarm would make. It just vibrates instead.
Username: Th77
Hey everyone,
I have a 04 Infiniti G35 manual transmission with the Viper 690xv installed on it. The other day when I went to disarm it like I usually do, the remote beeps but doesn't disarm it. I go in the house and grab my other remote and same thing. The remote beeps and the lights flash twice and beeps like it always does but the alarm led light is still blinking and the alarm goes off when I use the key to unlock the door and enter. I didn't know about using the valet switch to disarm it so I unplugged the alarm brain. When I plugged it back in, I could arm and disarm the alarm just like before but now, my trunk won't open both from the remote and from the car trunk release button as well as the doors won't lock and unlock from the remote or from the car's lock/unlock switch. Lastly, the passenger side window won't roll up or down at all now. Any ideas? Thanks guys.
Username: Manthatwassick
I need the installation and remote configuration manual for a Viper 200 alarm with remote start for my motorcycle
thanks
Username: Maldorox
Bentonville, Arkansas
I have an original CLIFFORD alarm installed in my 00 Dodge Neon. I lost one of my remote and the last one doesn't work fine. So, I tried to buy another control but the problem is its configuration.
If anyone could help me to find the way to program the new control WILL BE EXCELLENT!!!
Thanks a lot !
Username: Sugarsweetangel
I dont know what i did but i dont know how to make my alarm sound again when i lock/unlock the doors. i have tried some combinations but
nothing proved to be usefull. so the doors are closed now but the alarm doesnt
sound. what should i do...
i have a viper alarm rpn 47it fccid ezsdei471
Username: Coolj
Foxboro , MA
US
Hi,
Does anyone know how to reprogram a 790xv viper car alarm/starter...?
The blue remote lights when pressed but nothing happens...when the door is opened the system will start clicking and the lights will flash but no chirp or alarm...}}
I have to press the valet 2x to start the car...
Any suggestions...?
thx
Username: Cider31
I have a Viper alarm, and it locked the car, I can't get it to start, I don't know the model but FCC ID is EZSDEI467, I looked under the dash and it has toggle switch underneath, I tried playing with it and didn't get anything out of it, My remotes battery is alittle weak that might be the problem(but it still opens the door locks so maybe not...) I just want to start my car. Can anyone help me out?
Thanks alot.
Username: ïdered
Hello, i have a Viper Alarm with FCC EZSDE1478, my problem is:
The Ignition got blocked sometimes and i have no idea how to unlock the ignition, can some1 help me with this?
Username: Ekiester
Duncan, Oklahoma
I have 2002 Mustang GT with Viper alarm system that goes off 30 minutes after you arm it, then when you reset alarm it will work correctly until disarmed. I have taken to dealer three times and they have not been able to fix it and don't even seem to care. Got any ideas?
Username: Hapyspaz
I know this has been asked several times, but I never saw an answer.
I recently purchased a used vehicle that has a Viper 479V alarm/transmitter. The battery on the remote was dead when I bought it; replaced the battery, it worked once, and now it doesnt. Every time I attempt to use the remote it responds with a delayed sequence of 2 beeps, 3 times.
I am wanting to install a new optima battery but I am worried that the alarm will freak out and the remote wont help me. Also, I have yet to see the LED on the dash light up.
Under the dash is a spring loaded button and a flip switch. Any help would be greatly appreciated.
Username: Rfpisasale
Would someone please provide the link to installation instructions for remote starter, Viper 160XVL? Thank You
Username: 92hatchcx
Gonzales, LA
i have a viper alarm i cant get working...the main component says VIPER 5900 and the remote FCC is
EZSDEI7701
IC is 1513-7701
and RPN 7701 V/P/X
can someone please help!!
I NEED TO PROGRAM MY REMOTE,
ONLINE INSTRUCTIONS WOULD BE GREAT!
Username: Rexliu
Hi, I'm trying to fix my girlfriend's car alarm (viper 500 ESP) but I don't have the installation manual. Both remotes just stopped working one day and she thinks it's a programming issue (I haven't really taken a look at it yet). Anyone know where I can get a manual? Thanks in advance!
Username: Lenny10
Long Beach, California
United States
Hi, I have a viper alarm system 350 HV and the led light on the remote works but it doesnt disable the alarm or enable the alarm. so now i cant drive my car. Anyone know how much a new remote costs? or where i can get one and also how to re-program my remote, if that is the problem. thanks in advance.
Username: Biglou442
WELLINGTON, FLORIDA
WEST PALM BEACH
I HAVE A VIPER ALARM REMOTE START REMOTE CONTROL . MY SON PLAYED WITH IT, NOW WHEN I OPEN OR CLOSE MY DOORS WITH THE REMOTE THE ALARM MAKES NO NOISE. IT DOESNT ARM ITSELF WTF. CODES ON BACK OF REMOTE ARE RPN 479V/P/X 2(66) FCC ID:EZSDE1478 SOMEONE PLEASE HELP A BROTHER OUT.
Username: Jrock
LAKEWOOD , WA
US
I had the Viper 514N installed in germany about 4 years ago and it worked great until the other day. The remote was not activated the alarm so I took the remote to a retail store locally and they replaced the battery,before work I tried the new battery and the alarm went nuts.
I could see the inside blue light blinking I pressed the remote and nothing happened. I tried to start the car and the alarm went off. I pressed the remote again and again nothing happened the alarmed kept blarring.
Finally, after a few minutes the blue light stopped and I could start the car. I haven used the remote in a few days because I can't control it's activation.
I got the model number off of the alarm siren. I'm not sure if that's the right number.
If any one has a manual for this alarm or info it would be appreciated.
jrock
Username: Variazand
Hi. I have a 4 door toyota camry and I believe I have a viper alarm with FCC ID EZSDEI467. The car has auto door locks, but I am only able to lock the driver side door when I turn on the alarm. Can anyone explain how to change the settings so that all four doors will lock? I would like to do it myself rather than pay someone. Thanks!!
Username: Jeffreycove
I have a Viper 150HF command start from 1997 in my 1998 Chevrolet truck. The remote finally gave out, so I bought a replacement remote EZSDEI491, two buttons red LED. Same one as the broken one. I was wondering if anyone knew where I might get a manual for this remote start system and how to program my new remote.
Thanks.
Username: Kandy_262004
hEY people i need help i have a viper alarm installed in my 2002 honda civic LX but yesterday the blue light doesn't blink no more and is still when i unlock the car and lock it back it won't chirp no more and the light will stay still....can somebody help me please?????HOW CAN I GET IT BACK TO NORMAL....THNX!!!
FCC ID: EZSDEI474V
Username: Lissa1962
my LED light on the dash of my 2002 tahoe doesn't blink, the alarm works perfectly though.
Username: Lissa1962
my LED light on the dash of my 2002 tahoe doesn't blink, the alarm works perfectly though.anybody have any ideas of what the problem may be? once i heard the wires may be loose or something like that. i don't know anything about wires and i rather it if someone could tell me what to do , and then i could give this information to someone who does know what to do with the info, and charge an arm and a leg for it. thanks in advance, lissa
Username: Lilpikaro
hello,
I need serious help with a VIPER XV160 REMOTE.
I bought a 1999 Lincoln Navigator and it has a viper alarm with REMOTE STARTER. the remote locks and unlocks the car but it wont start it. It makes the sounnd like its going to start but it doesnt!
PLEASE HELP with programing the remote. Winter is approaching and need to warm up the car for the kids. thank you.
Email me at lilpikaro@hotmail.com
Username: Drod
I have a viper alarm system (550 ESP). I purchased 2 remotes FCC ID. EZSDE1476. Can anyone please tell me how to program them?
Username: Viennadriver
I had a very basic remote starter installed in my Volvo XC90 that seemed to be working fine until last week. I had left the emergency lights on in my car for a little over an hour and when I returned to the car I started it with the remote. Instead of putting the key in the ignition first, I inadvertently reached for the emergency light button and turned it off. This action obviously killed the engine and when I tried to restart it with the car key, the car wouldn't start - no noise, no action, nothing - just dead. It wasn't a battery issue because the horn, locks and emergency lights were working fine. I had the car towed to the Volvo dealer and they couldn't figure out how to disable the remote starter. Eventually I had a technician from the place where I bought the remote starter go over and disconnect & remove the device. Even then the car wouldn't start. While Volvo technician's are figuring out the problem, I'd like to find out if it is possible for the remote starter to hack the car's computer. Or could this be some other problem with the car's starter? Although my car is still under manufacturer's warranty, I am afraid that whatever major (or minor) malfunction has occurred, the Volvo dealer might hold me liable for repairs/replacement parts because they will blame the problem on the remote starter that wasn't supplied by them. Has anyone faced a similar situation? You can email me at dilkash1961@yahoo.com.
Thanks!
Username: Slammer1977
Port alberni , Bc
Need help with a Directed\clifford alarm system model avital 2200. stopped working about 2 months ago except for remote keyless entry.tonite it started going off and would not be stopped with remote had to disconnect the car battery. no warrenty or manual as it was in the car when i bought it three years ago. it has immobilized my 92 ford explorer no power no lights nothing! any ideas??
Port alberni , Bc
Just to help anyone with the same problem the starter was shorting out and causing the grounding system to corrode severly, interupting the power supply. new starter,new ground wires, and new battery terminals solved the problem. thanks
Username: Druss25
Saginaw, Mi
US
I have a Valet Remote Start 561R system in my 1998 Chevy Silverado and I was wondering how to program the keyless entry without taking it some where and paying. If you know how let me know.
Thanks,
Dan
Username: Bmw_avital
i have a Avital alarm system in my BMW, the red light in dash stays lit all time, doesnt flash anymore
is there a series of buttoms onthe remote I press to reset the system to normal (chirp on & off & flashing dash light)someone help plzzzzzzzzzzz
Thanks
Username: Larryb1963
I have a Valet remote start model 551T it must be a first generation unit as the newer one has diff, wiring this unit only has two plugs one has 5 wires red,yellow,pink,orange,purple,
the other plug has 12 wires. or,bl,br,br,wh,gray,gray,bk/w,wh/bl,bl,yellow,bk.
can someone e-mail me info on these wires so I can install it .Thank you larryb1963@aol.com
Username: Tizlom
Brooklyn, Nrw york
Username: Heather876
I have a viper 600 esp alarm. The remote got sumberged in water, and now i only see a flashing or blinking red light, can this remote be saved or do i toss it?
Username: Nickshade
hey can someone help me with my car alarm..
it won't lock or start my car. i replaced
the batterie and its still not working.
i don't know what's wrong :[
can someone please help me.
and its ID is EZSDEI475
thank you
Username: Casanosa11
Hopefully someone can help me out. I have the Viper system with remote start and the 4 button remote.
Now this has happened a few times, but usually starts working again when I pull the fuse and put it back in. For no reason the remote stops working. It functions properly but does not register to the system. It beeps as if it were out of range. This time nothings working and as soon as I put the put in, the alarms goes off and there is no way to shut it off. I tried the program steps and nothing happens, the alarm keeps sounding.
I dont understand. It started just like the other times (its happened twice). I parked the car. Hit the aux and start (orange) and the same time (its the turbo timer feature, runs for 60sec), got out and hit arm, and it everything like it should. As I was walking out of Office Depot I hit disarm/unlock and it does the out of range beep. Since then (this was yesterday) it will not register the remote.
Please help me out... thanks
Chris
Username: Kamalsny
I have an extra remote for my Viper 5900. Can someone me a .pdf file on how to progrram it. Since I am not a registered user for directed electronics, i can't access the .pdf links above.
If someone can help me program my remote that would be great. Please email the .pdf to,
gujushah@gmail.com
Username: Dani09
I am working on installing a Viper 5900 in a 1994 Chevy Camaro. The security and keyless was working fine, but now the doors are not automatically locking when the car starts or unlocking when I turn it off. Today, the system kept registering the shock sensor going off when it never did, and the LED won't stop the double pulses, even when the car is running. I have yet to get it to remote start. I used a relay to bypass the Passlock 2 system, but I am getting no voltage on the starter wire when I try to remote start. The car still starts with a key. Any ideas?
Username: Chillinva06
I just got the viper 5900 installed, is there a way to get that annoying fake-me-out siren deactivated and get my horn to work so that when i lock and unlock the horn beeps instead of the siren?
chillinva06@gmail.com
Username: Jesterbass21
I just bought a new yukon that has a 474 vx or xv lol anyway I programmed the remote and the lock button locks and unlocks the door lol. also I only have to push the button once for it to start up. and after it starts the parking light flash until I put the key in and hit the brakes. also I cant shut the engine back off without hitting the brakes. sooo... anyone know how to make it so I can push the button again to shut it off? and make it so the parking lights dont just flash and also how to program the "emergency" button on the remote??? and one more thing wich wires are used for the horn? you can email me if you want mcallistermaintenance@hotmail.com
if you just wanna give me a manual I could figure it out but I cant log onto directed.
Please Help........
Im sorry its the 160 xv thats what it says on the brain
Username: Zeyoner
Can someone please send me the pdf to zeymobile@gmail.com
474V
Username: John02
ive got a viper II alarm. something went wrong with it, It wont let me start my car, and if I kick start it the alarm keeps going off... How do I fix the problem?
PLEASE HELP ME WITH THIS!
Chris
Username: Alexband
West plains, Mo.
U.s.
hi
i got a 2006 scion tc with a viper alarm installed in it. i got a new remote for it but it came with no insrutions on how to program it. its a 488 vpx 3002 model #
is there any way you can help?
Username: Krook01
Viper EZSDEI471t Car Alarm will not chirp.Doors lock and unlock but no sound..can you help me? Krook01@gmail.com
Username: Mmsiddique97
Hi,
I have a viper 300 security system in my corolla, some how it went into a silent mode where i dont hear the chirping sounds when arming and disarming.
Does any one know how to get it back to normal.
Thanks in advance
Username: Sugasofresh14
****Hello Every1, I am in need of desperate help!!!!!****
I bought a Viper 7900 Remote start alarm 2way... At First it was working perfectly! But just last nite i armed the alarm.. after i armed it, I was messing with the remote and for some reason IT all of a sudden the pager started saying "Transmitting, OUT OF RANGE"... So i just ignored it and left it along... So this morning when I wake up, i try to Engage the remote start but the pager noted "Transmitting, OUT OF RANGE".. So I go down stars and stand next to the car and try to unlock it... but it still kept noting "Transmitting, OUT OF RANGE"... So i manually opened the car and the alarm was going off Like Carzzy!!! So i Had to disconnect the Siren... I then go inside and try to active the VALET switch but its not working, Unless i didnt know what i was doing? How many times am i suppose to Press to Engage Valet?? Well as the alarm is going off the remote is also paging its own siren!!! So this stuff P-me off, so i just unplugged the Brain, just the pins w/ the Power... I reset my remote by pressing the tiny whole in the back (pager) and then plug in the Brain.. Well now the remote dsnt page nor does it respond to the alarm... how can i reprogram the remote and just reset the whole alarm???
****Please help***** you can email @ sugasofresh14@aol.com
Username: Kooroc
I have a 98 toyota corolla i bought from someone else. I think this car has one key for ignition and one to open doors. either way, i cannot open the doors with the key, so i use the remote for the keyless entry. It jst stopped working today and i cannot enter the car. I replaced the battery on the remote but still to no effect. Any help will be greatly appreciated. The FCC ID on the remote is : EZSDE1476.
Thank you.
Username: Pri217
Hi!
Somebody please help me. I just bought a used 1999 acura integra. it has a viper keyless entry alarm system fitted by the original owner. So I dont have any manuals.
A blue light was blinking on the dashboard when I locked the car. I have the car since a week and I haven't noticed this blinking blue light before.
I know this is a silly question related to the forum above but I'm very freaked out.
Username: Baggedon20s
Flevoland, Florida
US
My buddy bought a car with a viper alarm system and it has poplocks for the doors anyways his gurl pushed the reset button on the remote and now it wont work any idea what to do??????
FCC ID: EZSDE1489
Username: Boomboomgrandam
Viper vx791 Question -
Remote: FCC ID: EZSDE1478
After fixing my alarms remote start (loose wire, long story, crappy install from the shop I bought it from and them trying to charge me to fix it! So much for that lifetime warranty on parts and install! )
My remote now only starts the car in timer mode (I think that's what it is called) By pressing the "Lock" and "UnLock" buttons at the same time. I can not shut the car off unless I go and press the Brakes.
When pressing the Start button (orange star button) The remote beeps like I would be using the AUX button to open the trunk, and the Number "6" shows on the remote. Nothing else happens that I am aware of. Can Anyone Help me restore it back to the way it should be?
Thanks in advance for reply's
-Shawn
Username: Bmason
I have a viper 479v fcc id: ezsde1478 that is not working - alarm goes off when I try to get in the car. I want to try to reprogram the remote but dont have the manual does anyone have the instructions or suggestions?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Security Systems > Viper alarm problems and how to progr... [ « Previous ] [ Next » ]
