Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > What kind of Amp do you recommend?
Author Thread: What kind of Amp do you recommend?
Username: Superx727
What kind of Amp do you recommend for a Audiobahn ABP10T subwoofer box enclosure?
I can afford to spend $200 at the most
Username: Rancid
Stockton, Ca
Us
Post Number: 7
how many watts and ohms is t
he sub
Username: Superx727
heres all the info:
Dual 10" Molded, Texture Injected Poly Cone
50 oz. Strontium Magnet
2" 4 Layer ASV Voice Coil
Power Handling : 600 Watts RMS
Sensitivity : 101 dB
Frequency Response : 30Hz -150Hz
Impedance : 4 Ohm Stereo
Username: Rancid
Stockton, Ca
Us
Post Number: 10
for under $200 i would recommend the profile AP1200 for about $169 or the kenwood KAC-7201 for about $200
Username: Superx727
I found the Kenwood for 100$ on EBAY, is that the best I can find for under $200 even on EBAY
Username: Rancid
Stockton, Ca
Us
Post Number: 12
try looking for for an audiobahn A8002T or a fosgate punch P5002 or P6002
Username: Superx727
Is that enough to power my subs?
Username: Superx727
Glasswolf, do you agree with this? is there anything you would suggest?
Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > What kind of Amp do you recommend? [ « Previous ] [ Next » ]
