Thread: WHAt WiLL sound Good |
Bronze Member Username: Vaio
Post Number: 17 Registered: Dec-04
| Posted on Tuesday, January 18, 2005 - 04:11 pm: |
This Q is not about car sound its about Flowmaster 40 Series Delta Flow for my 1997 Ford ranger 3.0L will this sound good. 40 or 50 SERIES DELTA FLOWMASTER Muffler. THANKS |
| Posted on Tuesday, January 18, 2005 - 09:05 pm: |
Well ive gotta 01 s10 4.3 v6 with flowmaster dual exahust,im not sure wut exact muffler it is but it sounds pretty good.Its not too loud not too soft.It kind sounds like its under water if you no wut i mean.But in my opion flowmaster is the way to go on any vehicle.Also i had a 93 nissan maxima v6 I think they put a 50 series on it and it sounded awsome. |
New member Username: Djr_81
Putnam valley,
New york
Usa
Post Number: 10 Registered: Jan-05
| Posted on Tuesday, January 18, 2005 - 09:56 pm: |
the 40 series is going to be the loudest in and outside the truck. 50 series are made to be quieter inside the interior but they are also quiter outside the truck. If you want it to be louder outside than the 50 but still be quiet inside look into the deltaflow 40 series. i was going to get a flowmaster for my car but i found a borla new on ebay for $70 shipped . here's a site for you, borlas for cheap http://www.exhaustproslinc.com/turbosmufflers.html |
Post Number: 18 Registered: Dec-04
| Posted on Tuesday, January 18, 2005 - 10:50 pm: |
thanks for the tips/help |
Bronze Member Username: Djr_81
Putnam valley,
New york
Usa
Post Number: 11 Registered: Jan-05
| Posted on Tuesday, January 18, 2005 - 10:56 pm: |
you're welcome. good luck finding that great exhaust note. |
