Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > WHAt WiLL sound Good
Author Thread: WHAt WiLL sound Good
Username: Vaio
Post Number: 16
This Q is not about car sound its about Flowmaster 40 Series Delta Flow for my 1997 Ford ranger 3.0L will this sound good. 40 or 50 SERIES DELTA FLOWMASTER Muffler.
THANKS
Username: Jonathan_f
GA
Post Number: 3029
Honestly, IMO Flows sound like crap on a 6 cylinder. It depends on what kind of sound you're after, but they sound really raspy on 6 cylinders. Chambered mufflers in general don't work well with 6 cyls and 4 cyls. They tend to be too raspy for them. I think you're better off with Walker Dynomaxes, Magnaflows, or something similar. You definately need true dual exhaust, if you don't you'll sound just like any import with a coffee can exhaust. There are plenty of sound clips on the net, you should do a search and find sites that let you download them.
Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > WHAt WiLL sound Good [ « Previous ] [ Next » ]
