Thread: Glass, Question for ya |
Bronze Member Username: Chada08
Post Number: 25 Registered: Jan-05
| Posted on Tuesday, January 18, 2005 - 01:34 pm: |
I recently bought this amp kit on ebay. I was wonderin whether or not i should stick with the rca's that come with the kit, or buy new ones. Any help would be great. Also, i was lookin at your website... your head unit cost over 2 grand? that's nuts, i hope it steers and makes coffee for u too! haha http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32808%26item%3D5744874228 %26 |
NorthWest,
Michigan
Post Number: 7406 Registered: Dec-03
| Posted on Wednesday, January 19, 2005 - 10:14 am: |
I'm sure those RCAs are fine. the CDA-7990 is a fantastic head unit. Only one I know using Burr Brown K-grade DACs and digital filters. It's reproduction quality is astounding, and the tuner isn't too bad either. It's great if you want flawless CD reproduction and optical outputs. Probably overkill for most systems though.
