Thread: Will my amp handle it???? |
New member Username: Shoaks
Post Number: 1 Registered: Jan-05
| Posted on Tuesday, January 18, 2005 - 11:40 am: |
Hi guys I have a JBL GT series 12" 1000w sub. I'm considering buying the JBL 500w 4 channel amp that 75rms per channel, my ? is, will the amp be able to handle it???? |
Gold Member Username: Carguy
Post Number: 1156 Registered: Nov-04
| Posted on Thursday, January 20, 2005 - 10:14 am: |
Why are you buying 4 channel amp? Are you going to use it for your sub? That amp bridged might be able to handle it but why not just buy a sub amp instead? |
Bronze Member Username: Sparkey2027
Barnstaple,
England
England
Post Number: 58 Registered: Dec-04
| Posted on Thursday, January 20, 2005 - 11:00 am: |
you need either a 2 channel or mono block amp. that sub is 250w r.m.s @4ohms. so look for an amp that gives out 250w r.m.s @ 4 ohms. try a alpine mrp 350. it gives out 200w @ 4 ohms, and its a good amp and a reasonable price. |
