Home > Message Board > Car Audio > Disc Changers > I have Pioneer DEH-6 wiring diagram i...
Author Thread: I have Pioneer DEH-6 wiring diagram if needed
Username: Cwjim
Columbus, Ohio
Usa
I have wiring diagram for DEH-6 CD/PLayer
Username: Savagebovine
can you email it to me by any chance?
jhughes00@hotmail.com
chizzle
I just bought a car with a DEH-6 installed, and I've been trying to find the user manual for it on the internet but its nowhere, not even on Pioneer's website. What I need to know is if the face is detachable, and if so, how do you do it? Can anyone help? Please email me - death_trip@hotmail.com
No, the face is not detachable. The frame around the face comes off, by inserting a wire in a special hole. Then the unit can be removed by inserting two special shims, one on each side. Or it can be mounted without the slide in tray, in which case you would have to remove screws from each side to remove it. Anyone know how to set the clock??
1. Press and HOLD the source button till the radio shuts off.
2. Press and hold the FUNCTION button, until display pops up, then release.
(If you do not have a function button, then push the AUDIO button.
3. Press the FUNCTION button again until the clock shows on the display
4. Press the UP and DOWN buttons to adjust the hours.
5. Press the LEFT or RIGHT arrows to move to the minutes.
6. Press the up and down to adjust minutes.
7. When complete, press the source button to exit.
LEA
I HAVE A AFTER MARKET CD PLAYER AND I NEED TO HOOK THE REMOTE WIRE TO IT BUT I DONT KNOW WHICH WIRE IT IS
lifedeuce
I bought a DEH-6 and now I'm trying to install it in a 1997 Toyota Camrt. The plug in's are different so I'm faced with having to wire wire it in. The problem is I can't figure out the Camry wiring diagram. Also I decided to test the Pioneer by testing it with the car battery. I put the yellow battery line on the positive and the black on the negative, nothing. Should I not be getting some power to the radio at that point? Thanks
my mum has got a 1997 camry, and i tried installing a new cd player for her and i had exactly the same problem. I rekon they made the wire that way to screw with our heads. I gave up after i fuked up the electric mirrors.
When testing the stereo before installation, you have to ground the stereo to something metal. That keeps it from short circuiting. I had the same problem as big_baird and lifedeuce until i asked an electrician about it.
Jim Foster, can you please email me that schematic for the DEH-6 tuner?
ELLIMIST111@hotmail.com
from JcMProductionZ
i just installed a radio in a 1996 camry today the problem that i faced the first time i tried must be ur problem, the RED and YELLOW cables have no power.... those cables are for the REAR speakers along with the white and black cables there if i remember the white goes with the red for 1 speaker and the black with the yellow for the other the real powr needed to power the stereo is on the SMALL cables, i dont remember what colors they are but i know that the GROUND wire is the BROWN SMALL wire, if you use ONLY the anntenna for ground the radio will shut off when the volume is turned up..one of the power cables is the blue small wire i dont remember any more wires ill check back on the installation 2morrow. i got everything working execpt the power antenna. cant find the power antenna cable nad watch it with the small GREEN wire it gets power from the LIGHTS (i burned the dash fuse :-D).... hope this is usefull
Username: Johnwharton
Can you please send me the DEH-6 wiring plans? chaseanderson@hotmail.com i'm trying to install the DEH-6 into a 95' saturn SL2, if anyone knows about my car's wiring i'd be happy to accept the help. thanks
Could I get a DEH-6 wiring diagram also at mikkey4u@hotmail.com?
I just instal pioneer system(KEN-P5250+CDX-P1210).it detech "ERROR 11" .how can i do ?
waximilian
well, ive had a DEH-6 since christmas and i am pleased with its preformance so far, but the other day i slid it out (i dont have it securly fit in but it always stayed in and never presented a problem) then i put it back in...nothing violent...i was parked, car was off, everything was cool....but when i turned my car on, the cd player wouldnt turn on and my clock was dim as hell ( i have a 93 civic lx) anyone have any ideas?? please email me maxwellsmart137@yahoo.com
I need a wiring diagram for a 96' Saturn SL2. Can anyone help me out?
Hello Boys. Could Jim, or anyone he may have passed it on to, email me a copy of those DEH-6 'grams? I'll love you forever! Thanks, Denise
could use a deh-6 wiring diagram also..Thanks
I also need the DEH-6 diagram, can anyone help? I will be greatful. dy@cimtel.net
Yesterday I took my cd player out of my 79 t-bird because it wouldnt play cd's and when I plugged the other cd player in, I got no power whatsoever. So then i tried plugging the old that worked in and that also didnt have power. So Im thinking that I must of pulled something out when pulled the cd player out. If anyone can help me with this please email me.
CoreyJoe
Yesterday I took my cd player out of my 79 t-bird because it wouldnt play cd's and when I plugged the other cd player in, I got no power whatsoever. So then i tried plugging the old that worked in and that also didnt have power. So Im thinking that I must of pulled something out when pulled the cd player out. If anyone can help me with this please email me. hay_cheefa@yahoo.com
I am attempting to wire up a automatic antenna on a 96 camry. I have managed to get the radio to work but I loose the radio memory every time I turn off the key. If anybody out there knows what the different colored wires from the original wiring harness go to, I would be forever in your debt. I had to cut off the plug on the end because the new antenna didn't have the same type of plug in capability.
Hello , do someone know if i can change the fm/am frequency ? in my coumtry it doesnt recieve and someone told me to find the manual and see if there is a function so i can make freq. jump diffrently. thank you for help ben
bentz787
oh forgot to say i have pioneer DEH-6
Please send here Thank you very much
Don@fat8balls.com
i really need the DEH-6 wiring diagram, because ive tried everything i know and it still isnt working right... please... anyone send it to me! thanks
Username: Rhblakeman
I just came across a DEH-6 from my daughter-in-law's car, had an engine fire so we yanked it before the insurance co totalled it (put the factory radio back in). Like always, she didn't retain the manual with the unit so I'm lost and need to wire it to the harness of my 96 Aerostar. I want to know the pinouts to see if it might have a cellphone mute that can be triggered on one of the existing wires or even the bare slots as well. Jim or anyone else that has gotten this info from Jim, could you email the pinout/diagram to me at rhb57@alltel.net ? Pioneer has the DEH-6 manual but only in paper format listed as YRD5009 at $2.71 - not bad but I'm not going to buy a manual if I don't have to, hate waiting and it might be better suited to my wife's car if it doesn't quite work with my Aerostar. It's just a cargo work van, not in need of powerful blow-out-the-windows audio but I have it and want to see if it's going to work for me. Thanks in advance.
Username: Emreaveley
Cortez, Colorado
I could use any information and wiring list for DEH-6 I bought car with it installed. No Information was provided. Thak you
I need the wiring diagram for the DEH-6 please. I've been looking everywhere for it. I also wouldn't mind one for a 93 mazda protege, but I can just buy the harness for that if I absolutely have to, it anyone knows the one for the DEH-6, please please please email it to me at
corbin1e@hotmail.com
It would be excellent if you could send me a copy of that wiring diagram. I actually have the DEH-P6700MP, but the wiring harness is the same.
Thanks alot for your help man.
jrocha@vcn.bc.ca
i am having problems with my amp and i was wondering if anyone had the wiring diagram for the deh-6 so i can make sure the right pins are being used. also, does anyone know if the pioneer can use the "Dimmer" feature a car has, even if it requires an extra pin attachment. email to ikeray@excite.com
I have 1986 mercedes and the harnessing unit were all cut off. All I have is a ton of wires. I bought a pioneer DEH from the junkyard and it has a bunch of wires. If someone out there knows where I can get a diagram or some help on connecting the stereo I would really appriceate the help. Thanks
Username: Jwoods2006
Cincinnati, Ohio
Usa
yes i have a 1990 plymoth acclaim and i have a deh-6 and need the wiring diraghram plz if someone could help i would be very gratefull email it to me at smokey_red_eyed_man_420@yahoo.com
Username: Bansheedragon
Phenix City, Alabama
US
Could someone please send me the wiring diagram. I bought this off ebay for my mothers birthday on Thursday. I would like to sneak and install before her birthday. Any help anyone can give would be greatly appreciated. Please email to: autigerdragon@peoplepc.com
Username: Maton
I also need the DEH-6 writing diagramn WOuld anybody please send it to me ASAP to Maton_One@hotmail.com
Thank you very much, I do realy need it.
Username: 44nneedit
Roseville, CA
United States
Can I too, get the wir. dia. for the deh-6, please. Thanks, Jemrx2@yahoo.com
Username: 44nneedit
Roseville, CA
United States
can you send me the deh-6 diagram, thanks jemrx2@yahoo.com
Username: Girs91mj
just got the deh-6 and need the wireing diagram. could you please email it to girs86mj@yahoo.com ASAP, thanks.
Username: Brodymulry
NOTE:
You need to make sure that there is a small (+12) signal wire also wired to your head unit, think of it like a REM/signal wire for an amp.
Without this, the AMP is powered, but will not turn on.
Why? Because, the small signal +12v wire is active when the Keys turn the ignition to either ACC (one before kicking the car over) or when the car is on. This allows you to turn on the head unit.
You can test this, by wiring the Unit directly to the AMP, and will a small 12v transformer, powering that on (the + wire) and it WILL power on.
It seems thats whats been missing above!
:edit:
Replace:
"Without this, the AMP is powered, but will not turn on. "
with:
"Without this, the HEADUNIT is powered, but will not turn on."
Its the same deal as an amp, I was just thinking about AMPS at the time
Username: Connollyt
Could you please sende me the wiring diagram for the DEH-6 to connollyt@charter.net. Thanks.
Username: Ddcross88
Foxlake, Il
Usa
If you have a wiring diagram of a pioneer deh-6 please email it to me,ddcross88@aol.com,i bought the cd player and two 12s to day and can't hook up the cd player
Username: Scorpion8686
Kansas city, Missouri
Could i get a copy of the manual to please..
anthony_wagner@kcmo.org
Username: Dbzfanatic_1
i'd like a copy as well plz dbzfanatic_1 at hotmail . com (skewed from bots)
Username: Radkosechko
Sofia, Sofia
Bulgaria
Hello!
I would be grateful if someone could send me a copy of the manual for the DEH-6, I have DEH-620 at home, with detachable facsia, think they must be similar, if in the meantime someone finds or has manual for the DEH-620, I would be most grateful.
E-mail: radko71@abv.bg
Thanks!
Username: Saiiagps
I need the wiring diagram for the DEH-6 also. Could someone share it with me?
Thanks
Username: Flammable
hey im trying to install a pioneer DEH- 1150 into my jeep, i tried to test it and nothing hapened, so does anyone have a wiring diagram for the deh-1150 or similar so i can get a basic idea
please email to me at bobsyaaunt94@hotmail.com
Username: Melbax
Johnstown, Pa
Usa
Bought a used DEH-6 Pioneer cd player stereo and I don't know the color codes and where they go to that is coming out of the player. The color code is missing so I don't know where to wire them to. Putting into a 91 Chevy Blazer. Any help would be greatly appreciated.E-mail me at mcochiese22@aol.com
Username: Wayenair
Groton, Ct
Usa
i went ahead and ripped out the head and changer units, they had already caused enough problems for me. so i did my research and bought an Eclipse AVN-5500. its a $1700 nav/audio unit but got it on ebay for right at $900 new. i assembled a harness using aftermarket harness adapters and the 2 units i talk about below. have had it in there about 10 months and i could not be happier. it has exceded all of my expectations. IMHO, i HIGHLY recommend this setup if you want to end the frustration of the crappy factory unit. and the Eclipse unit is very accessorisable. plugs installed in the unit allow plug-and-play of a rear-veiw camera, HD radio, sirius radio, cd changer, amp, and more. it works great with the bose system once the gain in the line level interface is set correctly. feel free to contact me if you need/want help with this. anyway, below are the 2 additional units required by this setup, they're about $20 each new.
when putting in an aftermarket unit, to retain use
of the steering wheel controls, use a Pacific Accessory Corporation SWI (steering wheel interface) unit. they are specific to the brand of the aftermarket head unit. here is the address:
also, when switching to the new head unit, to adapt the bose system to the new head unit, you need to use a hi/lo line level interface so the signal from the new head unit will be at the right level for the factory bose amp.here it is:
http://www.pac-audio.com/products/productsCatagory.asp?mmSearch=Steering%20Wheel %20Interface
http://www.scosche.com/scosche_caraudio.aspx?CategoryID=229&ItemID=OEA4
Username: Wayenair
Groton, Ct
Usa
disregard my last post, i was in the wrong thread.
Username: Bigtpdoagmailcom
Edmonton, KY
United States
Yeah I am also in need of the wiring diagram for the DEH-6 cd player. It would be greatly appreciated if someone could send it my way through this email bigtpdoa@gmail.com thank you very much
Username: Fiestadeb
It would be greatly appreciated if someone could send it to me at fiestadeb@hotmail.com
Thank you very much
Username: Back2
thanx
Username: Jmingels
Westwood, MA
i also need the diagram for the DEH-6 if someone could send it to me that would be great mingels_josh@hotmail.com
Username: Scoot
Gopher Ridge, Florida
I could use a copy of the wiring diagram. My kids brought one home for "Daddy's T-Bird".
Sc00ter@myway.com
Thanx for anyone helping!
Scoot
Username: Lft
Does the Pioneer DEH-6 support any ipod connections?
If so, what and where do you get them?
Thanks!
Username: Saku
Victoria , BC
Post Number: 13
If anybody still visits this thread who has a copy of the wiring diagram for the DHE-6 could they send me a copy please.
colbynye@shaw.ca
Username: Mcg
I need the wiring diagram as well. Thanks
nohellforme@hotmail.com
Username: Kansei
Ok. My radio (just bought it used...) says DEH-P660. Is this the same radio you all are talking about?
and If so... plz send me the pinout diagrams at FLAMEBOYAA@MSN.COM
Username: Fenriz
Jackson, Tennessee
Usa
would like a copy of those diagramsplz. calvinsrage@hotmail.com
Username: Tuib7
can i have a copy too please??? this stereo is driving me nuts!!!
thanks
tuibarton2007@xtra.co.nz
Username: Troll
can I please have a copy of whatever diagrams and manuals you have for the pioneer DEH-6.
thanks a million
slipperyjimdegriz@gmail.com
Username: Antia
check this if you need any parts about audio
www.jupoco.com.cn
IC, CD/DVD changer/loader
Username: Irishboym4
does this deh 620 deck have RCA outputs. i want to know b4 i go taking it out of the dash just ot see
Username: Crunkstar005
can you please e-mail me the wiring diagram?
crunkstar005@yahoo.com
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Disc Changers > I have Pioneer DEH-6 wiring diagram i... [ « Previous ] [ Next » ]
