Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Amp for Focal 165W and 690CA
Author Thread: Amp for Focal 165W and 690CA
I have focal 6.5 components with RMS 100, Max 200, and 6X9 with RMS 75 and max 150.
What amp should I get?
I have been told
Eclipse PA 5422 but I am wondering if it has enough power.
Also been told fosgate P8004.
I am looking for an amp that will not burn out or blow my speakers with good control and great quality.
What do you suggest?
Space is not an issue and I have bought a 0 gauge wiring kit
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 432
Jl 300/4 would work nicely, 75 watts rms all the way around.
Username: Audio_fanatic
Mukilteo, Wa
Post Number: 25
actually, 75 watts is not enough for those focal utopias. They need a good amount of watts, i would recommend about 150 or 125 at least to those. A good amp would be the jl 300.2 for tha focals, and then a cheaper one for tha rear.
Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Amp for Focal 165W and 690CA [ « Previous ] [ Next » ]
