Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > How important is preout voltages?
Author Thread: How important is preout voltages?
Username: Themax96se
Post Number: 55
When looking for a head unit, how important is preout voltage when hooking up to amps? What else is there to look for in purchasing HU's with an amp set up in mind?
Username: Carguy
Post Number: 1157
Look for the features you want/need first. Do you need dvd? MP3? Surround sound? Most HU's will give 4v preouts and that's fine with most amps. However, some will give 6v - 8v. Those cost a lot more. Higher volts will give cleaner sound.
Username: Rds11
Louisville, Kentucky
Post Number: 58
Like Isaac said it makes a cleaner signal to the amp if the voltage is higher. Some of the low - mid grade H.U.s have 2v preamp outputs as well.
One more thing, Make sure your amp can handle whatever voltage you are putting in it. For example, A certain MTX amp can only take up to 5 volts of input power. So an H.U. with a 6 Volt rating is too much. Im not sure if there is a way to lower the voltage or not on an HU. Maybe sum1 else knos
Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > How important is preout voltages? [ « Previous ] [ Next » ]
