Thread: suggest Amp/Brand for Bus. |
space adventure Unregistered guest |
| Posted on Monday, January 17, 2005 - 06:20 pm: |
any Amp or brand suitable for bus.Any 2 channel sterio amp.should be at least 500watts RMS.
Gold Member Username: Carguy
Post Number: 1136 Registered: Nov-04
| Posted on Tuesday, January 18, 2005 - 04:04 pm: |
You can find 1000W rms amps from Zapco, Orion, PPI, RF, Kicker, JL, JBL, Audiobahn HCT series, MTX.
Bronze Member Username: Ahmer
Hyderabad,
Sindh
Pakistan
Post Number: 49 Registered: Dec-04
| Posted on Thursday, January 20, 2005 - 11:55 am: |
hmm, which one will be more louder in your openion or it depends on headunit . |
Post Number: 1159 Registered: Nov-04
| Posted on Thursday, January 20, 2005 - 01:26 pm: |
Zapco if you can afford it, then Orion, PPI older amps, JL and the rest. |
