Thread: What subs should i buy to go with my amp? |
avenger97Es Unregistered guest |
| Posted on Monday, January 17, 2005 - 01:20 pm: |
I have a Kicker SX700 4 channel amp..and im wondering what i should get for subs/sub...i was thinking a pair of L7's but give me some input... |
Bronze Member Username: Sparkey2027
Barnstaple,
England
England
Post Number: 62 Registered: Dec-04
| Posted on Friday, January 21, 2005 - 07:37 am: |
that aint gonna happen. to run subs you shood really get a 2 channel bridgeable or a monoblock amp. that kicker amp will be ideal for powering your speakers but not subs |
Bronze Member Username: Byrumjr
Post Number: 26 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 01:32 pm: |
The Kicker SX700.4 4 Channel Amplifier 175 watts RMS x 4 at 2 ohms 350 watts RMS x 2 at 4 ohms bridged The Kicker Solo-Baric L7 12" Dual 4-ohm Voice Coil Nominal Input Power Rating: 75 to 750 W each The way I see it this amp is more four running a small system not just subs. You could hook one of the L7s up @ 350 watts RMS x 2 at 4 ohms bridged. Take your amp from 4 channels and make it 2 channels. Hook each channel from the amp to each side of the Dual 4-ohm Voice Coil on the same sub. The amp will see a load of 4ohms on each channel. The sub will get 350RMS to each coils making 700 watts RMS to one sub. All this is if the ratings are true and still it will be hard on you amp to push one L7and it would not push it to it‘s potential. Hook you whole system to the amp and get some good 12’s @350 watts RMS |
| Posted on Friday, January 21, 2005 - 04:13 pm: |
HELP, I now have a cd player and 4 speakers in my boat. Want to add an amp and 8" passive bazooka tube sub. What do I need for an amp (wattage)(2 or 4 channel) to power this? Do I need a powered sub? Very new at this!! Any help appreciated. Randy |
