Thread: Glasswolf.please read and try to help |
chitown guy Unregistered guest |
| Posted on Sunday, January 16, 2005 - 04:12 pm: |
1 last question.ok my subs are 200watts rms and 400 peak.lets say i went ahead and got 2 more subs and 2 of those amps.that gives me 8 subs at 4ohms and 2 1200.1 amps right and if i hook up 4subs to 1 amp at 1ohm THAT WOULD GIVE ME 300WATTS TO EACH SUB RIGHT BETWEEN 200 AND 400 WITCH THE SUBS ARE RATED and if I do the same with the rest would that be logical?or am i still lost.[LOL]ok i had 2 questions the last one is if that will work would you think it would hit as hard as i need and would i need to look for anything special in my head unit thanks for the info and thanks for all the future info in advance |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 349 Registered: Nov-04
| Posted on Monday, January 17, 2005 - 12:51 am: |
you can't feed the subs more than their RMS rating, i.e.: 200W. If that's a kicker 1200.1 amp that you have, you can run all 4 subs off that 1 amp |
Silver Member Username: Rzarector
Coquitlam,
Bc
Post Number: 117 Registered: Dec-04
| Posted on Monday, January 17, 2005 - 03:22 am: |
not necessarily .. i guess it depends on how well made the subs are tho.. cause i know Rs can take alot more than there rms rating and im sure others can to i can say tho cause i havent used any other. plus its not like the subs will be getting 300 unless hes just got the thing cranked all the time |
Gold Member Username: Carguy
Post Number: 1119 Registered: Nov-04
| Posted on Monday, January 17, 2005 - 09:48 am: |
I have a question for you, why would you want 8 subs?? Do you even have that much space? Have you tried getting 2 15" subs with higher power ratings instead? For example, you could get 4 200W subs or 1 15" 1000W. What are you after? SPL or SQ? In theory, 4 10-12" subs will give better SQ than 1 15-18" sub cause smaller subs will respond much faster. |
