Thread: Best Car Security System |
New member Username: Sm68
Post Number: 2 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 03:10 pm: |
Hi, what is the best car security system on the market? Why is it the best? How much does it cost? Thanks
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 426 Registered: Jun-04
| Posted on Sunday, January 16, 2005 - 07:27 pm: |
Best huh? Well the best in my opinion would be the Clifford G5 solaris 5 or avantguard 5. I have delt with Cliffords for years and been very happy with them. As for what makes it the best: Life time waranty Fully programable You can turn each sencor on and off with the remote, without leaving your eazy chair. Auto start that will even start you car if the battery starts to get low (great for vacations)(be sure to warn the neighbors) Coded valet switch I could keep going for a while, but to make it easy here is the manual. www.clifford.com/g5/default.asp www.clifford.com/g5/sec_rs/default.asp#avantguard5 www.clifford.com/guides/g5.asp As for price your looking at about 4 to 5 hundred installed.
Post Number: 4 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 08:31 pm: |
Jeremy, the Clifford Avantguard 5 looks like a great security system. I will check out the Clifford website for further information. Is the Avantguard 5 a new model? I would hate to buy a system and then find out that they stopped making parts/accessories for it. Thanks |
Post Number: 427 Registered: Jun-04
| Posted on Sunday, January 16, 2005 - 11:06 pm: |
Yep that is a 2004 / 2005 model. What makes it even cooler is that it is backwards compatiable with all the G4 sensors. So not only do they still make stuff for it, but the old stuff works too. As for the parts, it doesn't matter if you have the waranty. Even if they stop making it, and the brain goes out, they will either replace it with a new model, or get a new brain of the same model. |
Silver Member Username: Rzarector
Coquitlam,
Bc
Post Number: 115 Registered: Dec-04
| Posted on Monday, January 17, 2005 - 02:59 am: |
jeremy do you know if this one alerts you if your alarm is going off.. id like to get one that would if u know of any . |
Post Number: 440 Registered: Jun-04
| Posted on Tuesday, January 18, 2005 - 05:36 am: |
Now were talking. You weren't playen when you said the best. www.clifford.com/matrix/responder/default.asp If that thing doesn't have every bell and whistle you want, then I can't help you.
| Posted on Tuesday, January 18, 2005 - 05:42 am: |
what are laser line alarms like?? any good? |
Post Number: 450 Registered: Jun-04
| Posted on Tuesday, January 18, 2005 - 07:10 am: |
I have honestly never delt with them. They seem to be a mainly British dealer. However looking at the price I would guess they are ok. close to 300 euros is pretty high. Another good way to tell is check out the people installing them. If you see that a company that caries them is using crimp conectors and so one to make conections then your probably dealing with a lower quality item. If they sodder and shrink tube all the connections (doing a higher quality install) then you are more likely dealing with a higher quality alarm. Basically comes down to money, why waist time doing a great install on a alarm that is going to take a dump in less that a year. |
New member Username: Whiteaurora01
Post Number: 10 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 09:57 pm: |
they are all the same viper, clifford, autopage just different names. to prove it the company that makes viper has about 6 or 7 alarms equipped with the same options with different names. It all a rip off the clifford has all the same options of an autopage if not more. |
NorthWest,
Michigan
Post Number: 7712 Registered: Dec-03
| Posted on Saturday, April 23, 2005 - 12:25 pm: |
look into Compustar alarms. http://compustar.org/ my personal choice.
NorthWest,
Michigan
Post Number: 7713 Registered: Dec-03
| Posted on Saturday, April 23, 2005 - 12:28 pm: |
I have the 2WSS-AS myself http://compustar.org/security_with_remote_start.htm
