Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > JL AUDIO
Author Thread: JL AUDIO
i have a jl audio system which includs a 1000\1 amp, 2 15w3v2, and a 3fard stinger power cap. it is brand new and have never had it hocked up i wanted to buy 1 more 15w3v2 but didnt know if my system (amp) could handdle it
please help me
shawn ballinger
thug_ak47_9@hotmail.com
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 419
Yep it will work just fine. Those speakers are rated at 500 rms, and you amp will give that much to both of them with out a problem.
even if i buy the 3ed one. i wasnt sure about the ohm pulling it to hard (im not sure how many ohm's they have there is 2 diffant ones u can get but i think i have the one with the strongest ohm's (or hardest on a amp) )???
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 425
Yeah I miss read it. That would be 333 watts each. Might be a little low, but it should work. Just make sure you wire it in 2 or 4 ohm. Tell us what ohm your voice coils are and someone should be able to tell you how to wire it.
Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > JL AUDIO [ « Previous ] [ Next » ]
