Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Can my amp. handle it???????
Author Thread: Can my amp. handle it???????
i have a jl audio system which includs a 1000\1 amp, 2 15w3v2, and a 3fard stinger power cap. it is brand new and have never had it hocked up i wanted to buy 1 more 15w3v2 but didnt know if my system (amp) could handdle it
please help me
shawn ballinger
thug_ak47_9@hotmail.com
Username: Oleg
Santa Monica, CA
Post Number: 352
what's the power rating on those subs?
Username: Carguy
Post Number: 1124
Shawn, that'll depend on your sub's VC and ohms. JL amp is 2 to 1ohms stable. Make sure you do not go lower than their minimum ohm requirements.
i dont know how many ohms my subs have there 15w3v2 i know there dual. should i jest leave it a 2 or buy the 3ed one
Username: Rzarector
Coquitlam, Bc
Post Number: 168
well u should kinda find out.. u want the voice coilconfigs to be the same either voice coil config x 3 subs will fit within the jl amps ohm range which is 1.5 to 4 ohms accually
3 dvc 2 ohm subs can yield a 3 ohm load on the amp
3 dvc 4 ohm subs can yield a 2 .67 ohm load on the amp
so the main thing is amp strong enough for those
the subs rms rating is 500 watts so that amp would be perfect for 2 i wouldnt bother adding a third
ok thanks
joe love
I would get the 3rd speaker the more the better
Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Can my amp. handle it??????? [ « Previous ] [ Next » ]
