Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > ******fOrd EscOrt Amp wIrIng******...
Author Thread: ******fOrd EscOrt Amp wIrIng******
Username: Benno_da_c
ne 1 know where i can thread the red power cable though on a 1993 ford escort i just cnt get the red cable into the car is there a rubber bung or hole ne where i can thread it through
CHI TOWN GUY
not sure on that car but in worst case do what i did and drill a whole in the fire wall i now its not right but i had no other choiceLOL
where/what is the fire wall
#1 i talked with glasswolf and he gave me a lot of help but i need to know how to wire all 6 subs to 1 mono amp.the subs are 4 ohms each and the amp is 1-2 ohms i cant find a diagram that showes how to CHI TOWN GUY
in the engin capartment under the hood all the way in the back find a spot and drill in to the in side of the car but go in the front seat and find a spot that is clear of wires
Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > ******fOrd EscOrt Amp wIrIng******... [ « Previous ] [ Next » ]
