Thread: Question ...A8002T |
New member Username: Knockinbme757
Portsmouth,
Va
Post Number: 4 Registered: Jan-05
| Posted on Friday, January 14, 2005 - 07:24 pm: |
I was wondering if the Audiobahn A8002T rated at 200X2 4ohms 400x2 2ohms would be able to handle my 12" dvc 375rms 750 peak each...if i hook it up at a 2 ohm load or would i have to keep the load at 4. |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 126 Registered: Jan-05
| Posted on Friday, January 14, 2005 - 08:50 pm: |
Is that just 1 sub, and is it 2 or 4 ohm dvc? |
Portsmouth,
Va
Post Number: 5 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 06:02 pm: |
its is two 12's both with dual 4 ohm voice coils |
New member Username: Vwtom
Post Number: 1 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 06:52 pm: |
keep the 4 ohms load. Both voice coils wired in series. This is useful when wiring multiple subwoofers to an amplifier. For example, wiring both coils of a dual 4 ohm subwoofer in series produces an 8 ohm load. Wiring this in parallel with an identically configured subwoofer produces an overal load of 4 ohms - perfect for most bridged two channel amplifiers. p.s. i`v seen cheap one on ebay |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 348 Registered: Nov-04
| Posted on Monday, January 17, 2005 - 12:29 am: |
what brand subs are those? |
Portsmouth,
Va
Post Number: 6 Registered: Jan-05
| Posted on Monday, January 17, 2005 - 03:39 am: |
Audiopipe |
Gold Member Username: Carguy
Post Number: 1118 Registered: Nov-04
| Posted on Monday, January 17, 2005 - 09:38 am: |
A8002T is a 4ohms bridged amp, so have your subs wired parallel to itself then in series for a 4ohms total load. Make sure you have the level/gain set properly. That amp seem to have a noise problem from my experience. When summer comes, I'm going to have it replaced with a whipser quiet cpu fan. The one inside is a cheap one.
