Thread: Amp install kits...which brand? |
Bronze Member Username: 70el_co
Fort walton beach,
Florida
U.s.a
Post Number: 19 Registered: Oct-04
| Posted on Friday, January 14, 2005 - 02:36 pm: |
what are the better comapnies, or which one is more recommended for a total maximum power output of 274 and 85 rms watts( kicker kx250.2) amp pushing 4 ohm component speaker sys? scoche(efx), phoenix gold, monster cable, street wires? which brand should i stay away from?
Gold Member Username: Carguy
Post Number: 1114 Registered: Nov-04
| Posted on Friday, January 14, 2005 - 02:43 pm: |
Hey Duarte, for that little power, you can go with any brand. In fact, wires are made the same way. Don't over pay for flashy packaging or brand name. I personally bought my wiring kit from Walmart. It was only $31. However, I would recommend that you buy a separate rca cable that's shielded and directional. Almost ALL amp kits come with cheap rca cables. |
| Posted on Saturday, January 15, 2005 - 08:36 pm: |
a lot of people recomend knukonceptz.com real good for budget minded people and it works great. |
Silver Member Username: Xxkmfdmxx
Saint Petersburg,
FL
Post Number: 240 Registered: Oct-04
| Posted on Saturday, January 15, 2005 - 09:34 pm: |
I just went with the cheapest one I could find on eBay, seems to be working good. |
Bronze Member Username: Themax96se
Post Number: 52 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 06:16 pm: |
knukonceptz.com, I've seen them on eBay, quality is known to be good. Even cheaper is still okay, Walmart sells scoche(efx) 4 guage for under $28, I have that... and I tell me friends to buy that. |
Bronze Member Username: Chada08
Post Number: 20 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 11:16 pm: |
yeah cept that walmart one is never in stock, i've been tryin to get it for a week lol. i'll prolly end up gettin one off of ebay for under 40 |
| Posted on Monday, January 17, 2005 - 07:40 am: |
Walmart will work but if you plan on running the wires to the truck of a long sedan you'll never have enough. Plus you don't get speaker wire with the kit. |
