Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > Simple question
Author Thread: Simple question
Username: Krijgy
Smithfield, Virginia
United states
Post Number: 35
when bridging your amplifier does that affect the ohms on the sub in anyway???
Username: Jlprix91
West, Michigan
Usa
Post Number: 49
no the subs voice coils do not change the load that the amp puts out changes
Username: Glasswolf
NorthWest, Michigan
Post Number: 7329
the impedance of the sub itself is a fixed value.
the impedance varies with the frequency the sub is producing, but the nominal load or average doesn't alter.
now, if you bridge the amplifier, the amp will see half of the actual load because you'll be using both the 12 volt positive and 12 volt negative power supply rails together to push and pull the sub, increasing the power into a 4 ohm load.
this means when the amp is bridged, it's only stable to twice it's load compared to running in stereo.
chi town guy
glasswolf i was told to come talk to you.lol.ok i just got six 12in subs.they are rockford fosgate rfp4412.they are 200 wats rms and 400 peak with a 4ohm connection and the frequency responce is 28-200hz the sensitivity is 87.5db ok now the problem is i have know idea what i just told you LOL i just read it off the box.but i do know i have a 1994 chevy astro and i had a box built to the speakers spesifacations so we are left with my question.ok keep in mind i want to get every bit of power out of these subs that they have.do you know of any amp/amps that would push these subs if not what should i look for when buying the amp/amps.and my second question is do i need a second battery,bigger alternator or a capassider if you can help i would be verry THANKFULL if not THANKS for reading and thinking anyways LOL
chi town guy
PS GLASSWOLF are these ok subs i just bought them cause i got a good deal-i think-and i know rockford fosgate is suposed to be good stuff when it comes to car audio ok thanks again
Username: Taylor17
Kopperl, Texas
Post Number: 113
They are ok sub's. Rockford makes ok stuff.
I am guessing that the subs are 4 ohm svc so they will be wired to 1 ohm?
If so you have a few choices on amp's
Overall just find an amp that put's out 800 watt's rms at 4 ohm's After you hook the subs up each should get 200 watts rms!
Username: Taylor17
Kopperl, Texas
Post Number: 114
Sorry just realised you said that you have 6 sub's not 4!
So that changes everything.
It will be hard to get just 1 amp to match that power with 6 ohms.
chi town guy
lol lol i thought about getting three but i thought it would make a nicer set up with one but im open to all ideas i just want to rock all six as hard as possible with out blowing any thing ps thanks
Username: Taylor17
Kopperl, Texas
Post Number: 119
3 would work nice! Just make sure each amp put's out 400 watt's at 2 ohms, so that way each sub is getting the amount of power it need's.
That will be a lot of money in amp's:-)
chi town guy
ok thanks..........................but will it hit hard or is it a waste of $$$$$$$$ and doy you know of any amps i should look in to??
Username: Glasswolf
NorthWest, Michigan
Post Number: 7335
you've got 6 subs. 200 watts, 4 ohms each.
you'll want 1200 watts RMS total.
with the subs wired in series/parallel the JBL bp1200.1 would be an ideal amplifier for you.
one amp that'll deliver what you want.
it runs about $200-300 on eBay or on-line retailers.
you'll also need a 4 gauge amp wiring kit for this amplifier.
larger wire if you plan to run another amp on the same cable.
chi town guy
so 1 amp will push all six subs to their max power?? and how do you wire in series/parallel? and will this put out a lot of bass..
THANKS FOR INFO
PS sorry about these crazy off the wall questions but i know nothing about this stuff just want a hard hitting system and dont want to blow my subs up LOL
Username: Glasswolf
NorthWest, Michigan
Post Number: 7337
yes lots of bass.
www.bcae1.com has a section on wiring multiple speakers. I think it's called advanced speaker wiring calculator or something.
you want the resulting load to be between 1 and 2 ohms.
chi town guy
ok sorry is that amp a mono amp 2 channel or muti channel????????????////again im sorry but thanks for your input also any websites to get this amp cause etronics does not have it and thats the only site i know.
Username: Taylor17
Kopperl, Texas
Post Number: 125
I believe it is a mono. Don't know any websites for that amp sorry!
chi town guy
ok that helps me on my mission atleast i know what im looking for nowLOLOLOL I THINK
Username: Glasswolf
NorthWest, Michigan
Post Number: 7344
yes mono amp.
www.ebay.com
search consumer electronics > mobile audio > amplifiers > "JBL 1200.1"
or try "JBL BP1200.1"
chi town guy
ok thanks again to both of you and if i get it ill let you know ok bye for now thanks again for all of your help
chi town guy
glasswolf i found that amp it looks nice but i can not find out hou to hook 6 4ohm subs to a 2ohm load on this amp and i looked on that sight and went to every spot on the right side i found all kind of help but i cant figure out how to do this can you help me again please.. thank you cause i would like to know how it works and is hooked up before i drop 4hundread plus on an amp again thanks for all the help and suggestions
Username: Glasswolf
NorthWest, Michigan
Post Number: 7351
the amp is stable down to 1 ohm, and puts out 1200 watts RMS at 1 to 2 ohms.
here is the exact page you need:
http://www.bcae1.com/srsparll.htm
http://www.bcae1.com/spkrmlti.htm
if these two pages are too complicated, you may just want to go with using 3 separate amplifiers with a distribution block.
Then just run one pair of subs on each mono amp for a 2 ohm load per amp.
Username: Benno_da_c
does ne 1 know where i can put the red power cable for a amp through into the car on a 1993 ford escort i cant find ne holes to push it through email me sounder_benno@hotmail.com send pics if possible.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7357
ben, buy a haynes manual for your car and find a gromet through the firewall yourself.
Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > Simple question [ « Previous ] [ Next » ]
