Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > PLEASE HELP ASAP!!!!
Author Thread: PLEASE HELP ASAP!!!!
Username: Yamahaboy2123
Post Number: 15
i just baught a audioban amp...a8000t i believe....well when i first hooked it up earlier it worked GREAT!!! it was a 4 ohms..and i wired my two 12's to 2ohms...now all i get from my subs is like high volume. they are moving back and fouth ALOT but no "thumping" is this my wireing job that is fuked up or is my amp settings bad somewhere?? i messed around with all of them but didnt really help..please help!!!
Username: Sparkey2027
Barnstaple, England
England
Post Number: 46
whats your cross over set at. whats the gain set at. is ur box suitable for the subs
Username: Carguy
Post Number: 1094
Why don't you put it back to 4ohms and test it again? If that works, then it's not the amp problem. Make sure you have the pos to pos and neg to neg wiring done properly. If you accidently reverse one of them, then you won't get the thumping bass.
Post Number: 16
yeah im going to check all that now. thanks for the help. my cross over is set at 90 i believe...putting it all in the car now. will let u all know what was wrong with it
Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > PLEASE HELP ASAP!!!! [ « Previous ] [ Next » ]
