Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > Good amp for kicker comp VR's..12's...
Author Thread: Good amp for kicker comp VR's..12's
Username: Maumee2007
Ohio
first...i need to know if id be better off with 2 ohm dual voice coil or the 4ohm dual voice coil..then more importantly..i want to run 300-400 watts RMS to these and ill have two of them..wat amp do i need?!? 2 channel? mono block? HELP ME
Username: Sparkey2027
Barnstaple, England
England
Post Number: 37
how much are you looking to spend. an audiobahn a800t will do the job its 800w rms at 2 ohm. so id get the dual 2 ohm versions. wire the 2 voice coils in paralell and wire the subs together in series.
that amp is about $150. but if you want i can suggest a better 1 if your looking to spend a bit more.
Username: Sploosh56
Ohio
Post Number: 488
Kicker KX 600.1
JBL 600.1
Wire them the same as walton said. Audiobahn amps are not very good. THey're ok. Kicker and JBL amps are much better. Look on ebay
Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > Good amp for kicker comp VR's..12's... [ « Previous ] [ Next » ]
