Thread: Amp Going Bad? |
New member Username: Kwbrunz
Post Number: 4 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 01:36 pm: |
I have an Orion HCCA225 amp and lately it seems one side is playing much louder than the other. Is the amp going out on one side? Any suggestions? |
New member Username: Ssj_4_vegeta
Redgranite,
Wisconsin
Usa
Post Number: 7 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 02:05 pm: |
first check all yoru hookups and if make sure everythin is making a good connection icluding the wire on the subs let me knwo hwo that goes for you |
Gold Member Username: Carguy
Post Number: 1055 Registered: Nov-04
| Posted on Tuesday, January 11, 2005 - 04:33 pm: |
I'll show you a better way to check. Reverse your rca cables (right to left and left to right). Now see if the other channel is louder. If not, then your amp is going. If it does, then your amp is fine. |
Post Number: 8 Registered: Jan-05
| Posted on Thursday, January 13, 2005 - 10:00 pm: |
I have reversed the RCA and the same side is still louder. This amp has built in crossover settings (jumpers). Could this be causing any problems? |
Post Number: 1101 Registered: Nov-04
| Posted on Thursday, January 13, 2005 - 10:17 pm: |
If your amp has separate crossover settings for each channel, then check that out. Since reversing the rca didn't make any difference, the fault lies somewhere on your amp.
