Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > Help With Amp
Author Thread: Help With Amp
Username: Abrar
I am completely new at this and wondering if anyone can help me out. I bought 2 JL 12w6's. Now i need to buy an amp that will run them well. I dont really know what specifications to hold the amp acountable to. My budget for the amp is around 300-400 so i was thinking the p6001 or the 1001bd from rockford. Would those be sufficient enough to run them and how would i wire them up. Thanks!
Username: Carguy
Post Number: 1059
If you're interested in RF amp, then try T8002. It is much better than P6001 series. That amp is 2ohms stable in stereo, so you should be able to wire the sub in parallel to itself for 2ohms and then attach them to the channels.
Username: Rds11
Louisville, Kentucky
Post Number: 49
The Kicker KX 600.1 would probably work very well for u too.
Home > Message Board > Car Audio > Amplifiers > Archive through January 17, 2005 > Help With Amp [ « Previous ] [ Next » ]
