Thread: Some information needed |
Bronze Member Username: Krijgy
Smithfield,
Virginia
United states
Post Number: 24 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 08:32 am: |
does anyone recall what fuese the PD 4000 amp from boss uses? ive looked everywhere and can't find it. |
Gold Member Username: Carguy
Post Number: 1060 Registered: Nov-04
| Posted on Tuesday, January 11, 2005 - 05:04 pm: |
What do you mean fuses? Are you talking about the fuse on the amp itself or the fuse on the power wire? |
Smithfield,
Virginia
United states
Post Number: 27 Registered: Jan-05
| Posted on Wednesday, January 12, 2005 - 09:30 am: |
the fuse on the side of the amp.
Smithfield,
Virginia
United states
Post Number: 28 Registered: Jan-05
| Posted on Wednesday, January 12, 2005 - 09:32 am: |
alos isaac i could use your help near the top of the amp. page. (need serious help and fast...) |
Post Number: 1070 Registered: Nov-04
| Posted on Wednesday, January 12, 2005 - 10:05 am: |
Are you missing the fuses on the amp? The best way is to look at the manual. It'll list the sizes. If you don't have that, then you might have to open up the amp. On the circuit board, it usually lists the size. Since that amp is 3000W, I'm guessing the fuse is at least 40A each. My 2000W amp has 4 30A fuses.
Smithfield,
Virginia
United states
Post Number: 32 Registered: Jan-05
| Posted on Wednesday, January 12, 2005 - 10:20 am: |
no i was just trying to find out the true power of the amp |
Post Number: 1071 Registered: Nov-04
| Posted on Wednesday, January 12, 2005 - 10:58 am: |
Oh well the rumour is that the PD series actually produce. Haven't tested it myself though. |
