Thread: Rockford f & 12"Kicker comp |
New member Username: Tahoe_man
Post Number: 1 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 08:19 am: |
I have a Rockford f amp 800watts, Can I use it with my 12"Kicker Comp or is it 2 much for the 1 sub? I have a 3434 eclipse head unit with Ample speakers in the doors.At this time I running a 300 watt Hart amp which sounds great but I want more of a harder hitting punch. |
Bronze Member Username: Taylor17
Kopperl,
Texas
Post Number: 81 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 07:19 pm: |
I am not sure what your kicker is rated at, but I think it is to much power. |
Bronze Member Username: Sparkey2027
Barnstaple,
England
England
Post Number: 29 Registered: Dec-04
| Posted on Wednesday, January 12, 2005 - 03:02 pm: |
is it a comp or a comp vr. also is that the rms wattage of your amp and is so, at what impedance is it. |
Post Number: 2 Registered: Jan-05
| Posted on Thursday, January 13, 2005 - 07:36 am: |
Josh the amp is 4 ohm but i understand i can change it to a 2 ohm. The Sub is a Kicker Comp. |
New member Username: Burly
| Posted on Thursday, January 13, 2005 - 07:51 am: |
can anyone help me with amp wires and where they go n what coulour is which???? |
Post Number: 3 Registered: Jan-05
| Posted on Thursday, January 13, 2005 - 07:53 am: |
Josh the amp is a 2003 model 2 channel, I'd assume RMS is 400 watts Not sure? I just don't want to blow my sub out of the box. the guy's that installed my system said it's to much if so i going to wait untill spring and add another sub or go with another brand. My son turns 16 in Oct. so everything i don't use i'll install in his ride. Thanks for the reply and what would u suggest in subs to handle the fosgate? Don
| Posted on Thursday, January 13, 2005 - 12:23 pm: |
can anyone help me? |
Barnstaple,
England
England
Post Number: 41 Registered: Dec-04
| Posted on Thursday, January 13, 2005 - 01:01 pm: |
im guessing that the amp gives out 400w at 4ohm. and because its a 2 channelamp it isnt 2 ohm stable in bridged mode. tht 12" comp is only 200w rms. so it probly will blow up a bit. subs i can reccomend for tht amp are 12" kicker comp vr 12" diamond cm3 if you want something cheap you could get a 12" audiobahn sub. |
Barnstaple,
England
England
Post Number: 42 Registered: Dec-04
| Posted on Thursday, January 13, 2005 - 01:02 pm: |
adam start a new thread. and tell us what you want to know |
Post Number: 4 Registered: Jan-05
| Posted on Friday, January 14, 2005 - 05:06 am: |
bacially i just wanted to know what colour wires go where??? i lost the instructions and am really clue-less |
chi town guy Unregistered guest |
| Posted on Friday, January 14, 2005 - 06:31 pm: |
adam are you still on here? |
