Thread: Is it possible to run 2 dual 4 ohm subs at 1ohm into a mono amp?? |
Bronze Member Username: Alpineblaster
Post Number: 26 Registered: Jan-05
| Posted on Monday, January 10, 2005 - 09:52 pm: |
need answer fast thanks |
Bronze Member Username: Rzarector
Coquitlam,
Bc
Post Number: 96 Registered: Dec-04
| Posted on Monday, January 10, 2005 - 10:49 pm: |
yes http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=14&image.y=6 |
Post Number: 27 Registered: Jan-05
| Posted on Monday, January 10, 2005 - 11:55 pm: |
on the diagram are those little pods representing 2 diffrent speakers or a dual voice coil???? |
Post Number: 28 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 12:33 am: |
if i have a 2 channel amp that is bridegable then can i use taht diagram to make it work at 1ohm? |
Bronze Member Username: Krijgy
Smithfield,
Virginia
United states
Post Number: 19 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 12:46 am: |
ok heres the answer: yes heres how : run two wires from the posititve lead on the amp to each port on the subwoofer box and do the same to the negatives so that in reality there are a total of 4 wires running from the amp. this will be a parallel setup cutting the ohms down to 2 a peice. then inside the box wire the subs up parallel according to the manufacturer and that will once again cut the ohms from 2 down to 1. any question? |
Post Number: 29 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 01:57 am: |
so run four wires from the amp in bridge mode or regular?? |
Post Number: 30 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 02:01 am: |
yeah it didnt work for me i have two alpine type x 12s with 4 ohm dual voice coils |
Smithfield,
Virginia
United states
Post Number: 22 Registered: Jan-05
| Posted on Tuesday, January 11, 2005 - 08:28 am: |
you can run it from each channel... i diddnt know you had a 2 channel ampso just run each channel positive to positive and negative to negative. then run it in parallel, sorry bout the confusion.
Mr. Know A Little Unregistered guest |
| Posted on Tuesday, January 11, 2005 - 10:54 am: |
if amp is stable @ 1 ohm just wire both subs in parallel. If stable @ 2 ohms wire both subs to a voice coil each. If only stable @ 4 ohms just wire both subs in series. |
| Posted on Tuesday, January 11, 2005 - 10:55 am: |
Gold Member Username: Carguy
Post Number: 1066 Registered: Nov-04
| Posted on Tuesday, January 11, 2005 - 11:29 pm: |
In case you're still confused, 2 4ohm DVC will give you 1ohm load. So you should be able to use 1ohm stable mono amp with them. To get your 2 subs down to 1ohm, wire pos to pos and neg to neg on each subs. Now you take the pos and neg from each sub and connect them to the amp's pos and neg. This will connect both subs in parallel, thus giving you 1ohm. |
Post Number: 37 Registered: Jan-05
| Posted on Wednesday, January 12, 2005 - 12:04 am: |
yeah it worked but i was trying to bridge it that didnt work since its a 2 channel amp |
Post Number: 1068 Registered: Nov-04
| Posted on Wednesday, January 12, 2005 - 09:19 am: |
If your amp is 2 channel, you can either attach each sub to the separate channel (make sure it's 2ohms stable in stereo mode), or you can bridge the amp and use it as mono (assuming it's 1ohm stable bridged). Either way, it'll work. |
jimbo911 Unregistered guest |
| Posted on Thursday, January 13, 2005 - 02:03 am: |
if thats true why cant i run my 2 12" 1241d type r's with my mrd m501? i was told that i could only hook up one sub to that amp and i needed to get another mrd m501 for the other sub. is that true? |
Bronze Member Username: Themax96se
Post Number: 45 Registered: Jan-05
| Posted on Friday, January 14, 2005 - 07:59 am: |
I think its because alot of 2CH and 4CH amps would not be stable if bridge to accept a 2ohm or less load... is this correct? |
Post Number: 1105 Registered: Nov-04
| Posted on Friday, January 14, 2005 - 09:28 am: |
Jimbo911, your mrd m501 amp is 2ohms stable. So to connect your 2 subs, make sure they both add up to 2ohms load. Let's say your subs are 2ohms DVC. Connect each voice coil in series so that you get 4ohms per sub. Now connect them together to get 2ohms total. It'll work fine in that configuration. If however, your subs are 4ohms DVC, then you can connect them in series to get 8ohms per sub and then parallel them to get 4ohms. Now it'll work as 4ohms load on the amp. Your goal is to match the subs' ohms to the amp's ohm requirement.
