Thread: Best amp 4 the money? |
New member Username: Choir_boy
Va
U.s.
Post Number: 3 Registered: Dec-04
| Posted on Monday, January 10, 2005 - 01:26 pm: |
What's up. I have a problem trying to select what would be the best amp to power a diamond audio m661 component set rated at 20-170 watts(rms).I've narrowed it down to 4 choices: the 300/2 JL audio 2ch. amp 4 329.99(150 w rms x2), the orion-6002 2 ch. 600 watt amp 4 289.99(2x150 at 4 ohms), the rockfordf. 551s 2 ch. 550 watt amp 4 289.99(140watts rmsx 2 at 4 ohms), and last the zapco reference ref350 2 ch. 350watt amp 4 379.99(2 x 100 watts at 4 ohms.What would be the best amp and why? All opinions appreciated. Thanks. |
Silver Member Username: Erik123456
Arlington,
Tx
Post Number: 335 Registered: Aug-04
| Posted on Monday, January 10, 2005 - 02:01 pm: |
I would say the JL, then zapco its close but the JL is cool bc it puts out the same power regardless of ohms and voltage |
Va
U.s.
Post Number: 4 Registered: Dec-04
| Posted on Monday, January 10, 2005 - 02:24 pm: |
thanks, people told me that jlmade some good amps,just wanted to see how they measured up |
Arlington,
Tx
Post Number: 336 Registered: Aug-04
| Posted on Monday, January 10, 2005 - 05:52 pm: |
no problem glass will know more about the orion but zapco's ref. series and jl's slash series are top quality for sure |
