Thread: What Should I Use??? |
Bronze Member Username: Counterstrike
Post Number: 30 Registered: Nov-04
| Posted on Monday, January 10, 2005 - 09:19 am: |
ok i have 2 15 inch alpine type r's 2 ohm running 500 rms power each. i have about 500 to spend on a amp i was wondering if JBL BP1200.1 1200-Watt Subwoofer Amplifier would work or is there something better i can get for my money but work better? thanks a lot |
Gold Member Username: Carguy
Post Number: 1062 Registered: Nov-04
| Posted on Tuesday, January 11, 2005 - 05:20 pm: |
That's a pretty good amp. If you want to compare, try RF T10001bd/T15002. The first one is rated 1000W @ 1ohm, 1500W @2ohms bridged. |
Post Number: 38 Registered: Nov-04
| Posted on Thursday, January 13, 2005 - 09:34 am: |
so that would be better if i got the T15002? |
Bronze Member Username: Sparkey2027
Barnstaple,
England
England
Post Number: 55 Registered: Dec-04
| Posted on Thursday, January 13, 2005 - 06:24 pm: |
id go 4 the 1001bd. 1500w is a little too powerfull. but i thought the 1001bd gave out 1000w rms @ 2 ohms tho isaac. and those subs cant be wired @ 2 ohms get a kicker kx 1200.1. it gives out 1200w r.m.s @ 1 ohm
Post Number: 1098 Registered: Nov-04
| Posted on Thursday, January 13, 2005 - 07:24 pm: |
The T15002 is 500W rms x 2 @2ohms, 750@ x 2 @1ohm and 1500W rms x 1 @ 2ohms bridged. So basically it's like getting 2 of T10001bd amp. You can attach each sub to a separate channel with T15002 amp.
Silver Member Username: Rzarector
Coquitlam,
Bc
Post Number: 107 Registered: Dec-04
| Posted on Thursday, January 13, 2005 - 09:40 pm: |
the 15s would easily take 750 watts |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 107 Registered: Jan-05
| Posted on Thursday, January 13, 2005 - 10:49 pm: |
Go with the T15002, it is a sweet amp! |
