Home > Message Board > Car Audio > Security Systems > Archive through June 01, 2006 > Which is the best
Author Thread: Which is the best
Username: Perrydog
Flint, Michigan
Post Number: 20
out of all the alarms out there what do you all think is the best, the top of the line, price dont matter just tell me how much it is and what it is
Mike lowery
Which is best?
Looking in my pants and seeing what God has blessed me with. That is the best. This massive woman pleasing tool can make any woman scream and moan louder than ANY alarm siren on the market. Something you know nothing about, I'm sure, based on your question.
Try looking up different models and seeing what you like. I could name a few alarms that are horrid in quality, but cost alot, and you'd probaly think they were great cause they were expensive.
Username: Ps1k0
Post Number: 109
damn, someone is PMSing
look into a viper or clifford.
something with 2way and remote start.
hope that helps
Username: Whiteaurora01
Post Number: 11
no that dosent help!!!!!! they are all the same viper, clifford, autopage just different names. to prove it the company that makes viper has about 6 or 7 alarms equipped with the same options with different names. It all a rip off the clifford has all the same options of an autopage if not more.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7711
personal choice. Compustar.
Username: Scab12886
Post Number: 136
hey glass. about how much does that AWSS-AS cost? i saw in another post that you had that one, don't remember which thread it was. it looks like a nice system though, i love the fact that the range seems longer than anything else out there. if that system is rediculously expensive can you suggest some other good ones? thanks in advance.
Username: Suleman36
Post Number: 1142
Yeah glass how much whould that compustar cost in comparison to somthing similar like viper or clifford and what is another good alarm besides Compustar?
Home > Message Board > Car Audio > Security Systems > Archive through June 01, 2006 > Which is the best [ « Previous ] [ Next » ]
