Thread: What size speaker wires for 2ohm operation? |
Bronze Member Username: Themax96se
Post Number: 32 Registered: Jan-05
| Posted on Sunday, January 09, 2005 - 09:23 am: |
I am using am 2CH amp, each channel carrying a 2ohm load. How short and large should the speaker wire be. I just read GlassWolfs site: http://www.wickedcases.com/caraudio/amplifiers.html and found out I should be running a bigger wire. |
| Posted on Sunday, January 09, 2005 - 09:40 am: |
A 12 gauge or 16 gauge speaker wire should be sufficient. I would problably use 16 gauge wire (just my preference) but either one would work. And about the length of the wire, obvoiusly it should be as short as possible. |
NorthWest,
Michigan
Post Number: 7255 Registered: Dec-03
| Posted on Sunday, January 09, 2005 - 01:07 pm: |
http://www.caraudiocentral.net/forums/showthread.php?t=551
Post Number: 36 Registered: Jan-05
| Posted on Sunday, January 09, 2005 - 01:17 pm: |
Thanks again GW |
