Thread: WHAT AMP Audiobahn AW1508T |
New member Username: Mrwigglez
Post Number: 1 Registered: Jan-05
| Posted on Saturday, January 08, 2005 - 04:55 pm: |
Im getting 2 15 inch Audiobahn AW1508T subs. Im totally new to car systems. What Amp would be good for these, I have about $300 for an amp. would a Audiobahn A1300HCT mono amp be good? Please help me im new at this. |
Bronze Member Username: Taylor17
Kopperl,
Texas
Post Number: 44 Registered: Jan-05
| Posted on Saturday, January 08, 2005 - 05:27 pm: |
What ohms are they and are they dvc. Also what is the rms for them? I don't think that amp is big enough! |
Post Number: 3 Registered: Jan-05
| Posted on Saturday, January 08, 2005 - 11:09 pm: |
2 dual channel ohms i think, rms is 2000 watts a piece. |
Kopperl,
Texas
Post Number: 59 Registered: Jan-05
| Posted on Saturday, January 08, 2005 - 11:24 pm: |
If they are 2 ohm dvc, and are 2000 watt's rms you will need an amp that puts out around 4000 watt's rms times 1 at 4 ohm's. I don't know an amp that big of hand sorry. What is the specs for that 1300 audiobahn? |
Gold Member Username: Jonathan_f
GA
Post Number: 2970 Registered: May-04
| Posted on Saturday, January 08, 2005 - 11:34 pm: |
Too expensive, you won't find a decent amp that will power those subs without paying thousands of dollars. If you were to spend all that money to power those subs, you'll eventually wonder why you did in the end with the results you'll get. Those subs are heavily overrated and inefficient. The cheapest good $300 amp that is powerful is the JBL 1200.1, so you'll need subs that work around that. |
