Thread: A GOOD .5ohm stable amp that will take to alpine type x's to the max?? Any recomandations? |
New member Username: Alpineblaster
Post Number: 9 Registered: Jan-05
| Posted on Friday, January 07, 2005 - 10:22 pm: |
Anyone one have any good suggestions for a good amp that is stable at .5ohms that will power 2 type x twelves 4 ohm dual voice coils that are rated at 1000RMS and 3000WattsPeak each so i was thiking something that will at least kick 2000RMS watts at .5ohms anybody got any ideas??? |
Gold Member Username: Jonathan_f
GA
Post Number: 2954 Registered: May-04
| Posted on Friday, January 07, 2005 - 10:32 pm: |
Look into US amps. They have plenty of powerful amps stable to .5 ohms. |
Post Number: 10 Registered: Jan-05
| Posted on Friday, January 07, 2005 - 11:06 pm: |
thanks anybody else no any? |
Bronze Member Username: Alpineblaster
Post Number: 11 Registered: Jan-05
| Posted on Friday, January 07, 2005 - 11:12 pm: |
those US amps are a little out of my price range but they are very powerful anything like that at a lower price range? |
GA
Post Number: 2955 Registered: May-04
| Posted on Friday, January 07, 2005 - 11:53 pm: |
There aren't many .5 ohm stable amps out there, honestly. Your best bet would be to get 2 mono amps that put out 1000W RMS at 2 ohms. |
Gold Member Username: Carguy
Post Number: 1032 Registered: Nov-04
| Posted on Saturday, January 08, 2005 - 12:21 am: |
If your sub is 4ohms DVC and you have 2 of them, how are you going to get it down to .5ohms? |
Bronze Member Username: Themax96se
Post Number: 18 Registered: Jan-05
| Posted on Saturday, January 08, 2005 - 06:20 am: |
yEAH, good question, ran together wouldnt that be an 1ohm load? |
Post Number: 13 Registered: Jan-05
| Posted on Saturday, January 08, 2005 - 06:04 pm: |
thats what i thought but when i run them together and bridge them down to 1ohm mono it wont work it cuts off when the base gets to high maybe im doing it wrong does anybody have a diagram or sumthin? |
Post Number: 14 Registered: Jan-05
| Posted on Saturday, January 08, 2005 - 06:07 pm: |
no when i brigde it it wont work it goes down to 1 ohm becuase the speakers are running at 2 ohms each so it cuts it in half or sumthin if i had 3 subs it would work becuase the ohms would be 1.35 but since i have 2 it goes to .5 ohms |
GA
Post Number: 2959 Registered: May-04
| Posted on Saturday, January 08, 2005 - 06:57 pm: |
Yep, didn't even pay attention to that. It would be a 1 ohm load. Nelson, two 4 ohm DVC subs will create a one ohm load. An Eclipse DA7232 would be a good amp to run those subwoofers, two channel Class D amp, 1000W per channel at 2 ohms. Of course, it isn't really cheap either. How much can you spend? |
| Posted on Saturday, January 08, 2005 - 11:30 pm: |
around 500-600 |
