Thread: Mono or 2 channels |
PsykoSomatic Unregistered guest |
| Posted on Wednesday, January 05, 2005 - 06:28 pm: |
if all i am running are 2 subwoffers would it make a differance if i was running a mono amp that had about 600 rms or if i was using a 2 channel amp with each channel about 300 rms if the subs that i am using are alpine 1221D 300 rms subs? |
Bronze Member Username: Taylor17
Kopperl,
Texas
Post Number: 18 Registered: Jan-05
| Posted on Wednesday, January 05, 2005 - 07:21 pm: |
No difference. The mono amp will work less so better in the long runn. |
New member Username: Themax96se
Post Number: 10 Registered: Jan-05
| Posted on Wednesday, January 05, 2005 - 11:09 pm: |
Mono amps are ussualy for just subs right? But why do they work better in the long run if they push out the most power? Will it be cleaner? |
Silver Member Username: Carguy
Post Number: 999 Registered: Nov-04
| Posted on Thursday, January 06, 2005 - 03:42 pm: |
Mono amps are for subs. There is no advantage of a mono vs stereo when it comes to sound. However, there are different types of amps. Class D are for subs, class AB can be used for full range and subs. |
Silver Member Username: Addicted2bass
Miami,
FLORIDA
Post Number: 139 Registered: Nov-04
| Posted on Thursday, January 06, 2005 - 03:49 pm: |
yeh and youre better off running class d amps if youre running a low ampere charging system. Class AB tends to take more power to run than class D's. I think its something like 20% amps more than clas D |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 375 Registered: Jun-04
| Posted on Thursday, January 06, 2005 - 05:19 pm: |
Class A/B is about 60% effeciant, and class D is about 80% effeciant. However as I saac said you only want to use class D for subs. The way it amplifies the music is diffrent than a class A/B. This diffrence in methods, is why a class D introduces alot of distortion which is very easy to hear on mids and highs. However it isn't near as noticable on subs. |
