Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2005 > Need help getting right amp.
Author Thread: Need help getting right amp.
Danny5221
Currently I have two kicker comp 12's being powered by a sony explod 600 x 2 amp. I realize I want to give my subs more power cause my xplod is a pretty crappy amp. I want to get a kicker 600.1 to power them but its says max power is 150w per sub. Does anyone think that I'll be alright with the kicker amp and if not what amp would be a better choice. thanks
Username: Hassan
Post Number: 29
i have two kicker compvr 15's powred by an mtx thunder801d and man it paunds i think you should look into that also rewmember that mtx underrates its amps
Username: Carguy
Post Number: 1000
You can try kicker 300.1 model and power both, assuming your subs are 150W each.
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2005 > Need help getting right amp. [ « Previous ] [ Next » ]
