Thread: Infinity Reference 605cs or Boston RC620? |
JohnTacoma Unregistered guest |
| Posted on Friday, February 06, 2004 - 10:31 pm: |
Hey, I bought a pair of Boston RC620 componants to put in the front of my tacoma x-cab, but upon opening up the door panels I found a pair of infinity reference 605cs in there from the previous owner(they were not amped). I wasn't planning on hooking the rears up at all (they're stock). I have an eclipse 5 channel amp and am gonna get a 12" sub. What would you reccommend I do: 1) return the 620s and just amp the 605s, 2)Install the 620s and amp them in a bridge config, leaving the rears alone (ie, don't use the 605s), or 3) amp the 620s in the front and 605s in the rear (no tweeters), or vise versa? I hadn't planned on there being infities in the doors, even thought the tweeters are on the dash. Now that I found out they are, I'm not sure what to do with them. What do you think? Thanks, John |
Post Number: 1085 Registered: 12-2003
| Posted on Saturday, February 07, 2004 - 01:10 pm: |
try the amplifier on the Infinities and see waht you think. if you don't like them, then replace them with the Bostons.
