Thread: Help, please! |
New member Username: Cg0424
Post Number: 1 Registered: Jan-05
| Posted on Wednesday, January 05, 2005 - 01:55 pm: |
I'm sure I have everything hooked up correctly. The reciever functions fine, the speakers in the car play, the amp powers on, but I am not getting anything from the sub? I have double checked everything. Anyone have any ideas? What can I check? |
Silver Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 167 Registered: Oct-04
| Posted on Wednesday, January 05, 2005 - 02:24 pm: |
check rca cables and gains and xover freq. Maybe head unit has a sub level out that is muted. What kinda stuff you got? |
Post Number: 2 Registered: Jan-05
| Posted on Wednesday, January 05, 2005 - 03:55 pm: |
Aiwa: with the sub out turned on. Pioneer 200w amp Pioneer 12' sub |
Tulsa,
Ok
Usa
Post Number: 171 Registered: Oct-04
| Posted on Wednesday, January 05, 2005 - 09:23 pm: |
All new stuff? Has it worked before? Does the light come on on the amp? The proble is either deck, amp, wiring, or speaker. Try to hook up another speaker to the amp. This will tell you if it is the speaker or not. Dbl check all the wiring. |
Bronze Member Username: Gunit777
Post Number: 27 Registered: Oct-04
| Posted on Wednesday, January 05, 2005 - 09:27 pm: |
i think it could be the RCA cable bcuz the way you describe it everthing is ok except the signal. or it could be that the bass is turned off by the head unit. If the subs are not new they could be blown or the RCA input on the amp is bad. soory i cant help out nemore i just cant think of nething else that could be wrong. let me know what happens. |
Post Number: 28 Registered: Oct-04
| Posted on Wednesday, January 05, 2005 - 09:29 pm: |
By the way r u sure that the wires from the actual sub itself are connected to the inner part of the box????? |
shanester Unregistered guest |
| Posted on Wednesday, January 05, 2005 - 10:35 pm: |
im wanting to put a good system in a 2003 chevy extended cab some say infinty some say others help if you have this setup also are punch xlc's anygood |
Tulsa,
Ok
Usa
Post Number: 172 Registered: Oct-04
| Posted on Thursday, January 06, 2005 - 12:46 am: |
sorry shanester. you cannot put a good system in that truck. the factory head unit has the computer built into it. If you take it out the truck will not start. |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 364 Registered: Jun-04
| Posted on Thursday, January 06, 2005 - 12:43 pm: |
WHAT??? Yes you can put a stereo in a 2003 chevy truck. Not to mention chevy has used the same head units for years and the brain is not inside of it. Thats beside the point. If you want to do a stereo and leave the factory deck, all you need is a line out converter. Shanester, I would go and listen to some stuff. It really comes down to what your taste are. I would figure out how much you want to spend, and start listnening to stuff in that price range. Once you get a better idea start a post asking for sugestons, and changes. It will be alot easer for us to help you out if we have any idea what you are looking for. |
Silver Member Username: Carguy
Post Number: 996 Registered: Nov-04
| Posted on Thursday, January 06, 2005 - 03:24 pm: |
Robert, there's a simplier way to test your sub. With your amp turned on and subs hooked up, attach the rca cables to the amp. Now with your finger, touch one of them lightly. It should produce a humming noise. If it does, then it's fine. If you hear nothing, try the other cable. One of them should induce some kind of sound. If you hear nothing, then your subs aren't hooked up or the amp is in protected mode. |
| Posted on Thursday, January 06, 2005 - 08:06 pm: |
i looked at memphis and jl audio also infinity i also like focal for the front and by the way i put a pioneer 9600 it with a gm buss interface guess what my truck starts and when you unplug it it still starts all you lose is a chime somme cars lose gauges,abs,chime,etc ive been with gm for yrs please will someone respond with the quality of these products who dont have strret gloww or zits im not into hacking my stuff up thnax |
Tulsa,
Ok
Usa
Post Number: 174 Registered: Oct-04
| Posted on Thursday, January 06, 2005 - 08:08 pm: |
You may need to turn the gain up to do isaac's test. Good idea isaac. |
Tulsa,
Ok
Usa
Post Number: 175 Registered: Oct-04
| Posted on Thursday, January 06, 2005 - 09:53 pm: |
sorry shanester. the quality of the afore mentioned products are excellent. unfortunately, they will sound horrible in that perticular vehicle. and yes, at first all you lose is a chime. then the lights go out, then the brakes, and then you lose your engine one cylinder at a time. If you want good info start your own post. This is an amplifier thread started by the guy at the top of this list. |
Post Number: 387 Registered: Jun-04
| Posted on Thursday, January 06, 2005 - 10:08 pm: |
all you loose is the chime, and the dome light. The ECU is still in the engine bay. You will not loose the engine. Not to mention stereos can sound really good in a truck. If they are installed properly. |
Post Number: 388 Registered: Jun-04
| Posted on Thursday, January 06, 2005 - 10:12 pm: |
Oh yeah I would go with the focal and Jl audio stuff if I was you. Thats the same set up I am about to go with. |
Tulsa,
Ok
Usa
Post Number: 176 Registered: Oct-04
| Posted on Thursday, January 06, 2005 - 10:17 pm: |
lol |
Post Number: 3 Registered: Jan-05
| Posted on Friday, January 07, 2005 - 09:05 am: |
I have solved my problem, but I'm not sure how. I unhooked everything and rehooked it again. The sub "miraculously" started working. I didn't change anything. Oh, well. Thanks for all the help and suggestions. |
