Thread: Amp Gains w/ HU w/1 Pre-Out |
Bronze Member Username: _andrew_
Post Number: 13 Registered: Nov-04
| Posted on Wednesday, January 05, 2005 - 11:12 am: |
I have a question that has been festering for days. If you have a HU with one amp pre-out, how would you set the gains if you used an RCA splitter to connect a second amp? If you had a 3v pre-out and you had the gain set at half, would you set two amps at a quarter, or could you set them both at half still? Please help. |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 349 Registered: Jun-04
| Posted on Wednesday, January 05, 2005 - 01:12 pm: |
Andrew I do not beleive spliting it will half the voltage. Should still be the same. So in reality the gain should still be set the same. Glass care to clarify for us? |
Silver Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 169 Registered: Oct-04
| Posted on Wednesday, January 05, 2005 - 02:31 pm: |
Turn them all the way up so it will be louder!!! lol |
Post Number: 352 Registered: Jun-04
| Posted on Wednesday, January 05, 2005 - 02:35 pm: |
Hay lucas who do you deal with in tulsa? I just looked at your profile 74115 admiral and yale huh? what you live behind the cemetary? |
NorthWest,
Michigan
Post Number: 7207 Registered: Dec-03
| Posted on Wednesday, January 05, 2005 - 04:06 pm: |
voltage stays the same. current is split so signal strength won't be as strong. ideally you don't use Y splitters anyway though. You'd use an electronic crossoverwhich incorporates a line driver to keep the signal strength where it should be when you have one pair of pre-outs and want to run to four or six amp channels. .
Tulsa,
Ok
Usa
Post Number: 170 Registered: Oct-04
| Posted on Wednesday, January 05, 2005 - 06:54 pm: |
Streets Audio. No I used to live off N. Sheridan, but I moved. Are you from Tulsa? |
Post Number: 360 Registered: Jun-04
| Posted on Thursday, January 06, 2005 - 12:22 pm: |
Yep used to live on king st. Just west of the old git and go. Streets huh? I have delt with them a little, mainly for wires, and stuff. I normally deal with Car Toys, I have been friends with all of them so long they take really good care of me. Thats basically were I got all of the stuff I installed for myself and friends over the years. Its kinda funny. I got offered a job by every car stereo install place in Tulsa. Then Jeff finally offers me a job there, and its to late. I just signed up to join the Air Force. Doh!!! |
Tulsa,
Ok
Usa
Post Number: 173 Registered: Oct-04
| Posted on Thursday, January 06, 2005 - 08:06 pm: |
well, good luck in the service then. |
Post Number: 389 Registered: Jun-04
| Posted on Thursday, January 06, 2005 - 10:14 pm: |
Thanks man. Hard to beleive that was almost 5 years ago. |
