Thread: Amp voltage |
| Posted on Wednesday, January 05, 2005 - 05:49 am: |
OK this is a very n00b question but could somebody please shed some light on the matter of amplifier voltage for me. Like what is the difference between 12v and 14.4v? I though all batteries were 12v or is there something I'm missing. |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 324 Registered: Nov-04
| Posted on Wednesday, January 05, 2005 - 03:06 pm: |
As the engine RPM's inscrease so does the voltage. |
NorthWest,
Michigan
Post Number: 7206 Registered: Dec-03
| Posted on Wednesday, January 05, 2005 - 04:01 pm: |
the car battery with the engine off or at idle is 12.5VDC. When the car engine is above idle, you get 13.5 to 14.4VDC because that's the alternator voltage. the alternator has to generate a higher voltage than the battery in order for the battery to be recharged.
| Posted on Wednesday, January 05, 2005 - 07:03 pm: |
ah ok. thanks lol |
Bronze Member Username: Hassan
Post Number: 30 Registered: Nov-04
| Posted on Wednesday, January 05, 2005 - 08:03 pm: |
i was also wondering about that do you have any idea if a 96 dodge neon alternater gives 14.4VDC volts or not becouse i was thinking about getting the mtx thunder 684 amp and it said its 60x4 rms at 12.5 and 85x4 rms at 14.4 so i was confused about how much i would actually be getting becouse thats a preatty big diffrence speacailly that my speakers rms are 100 |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 361 Registered: Jun-04
| Posted on Thursday, January 06, 2005 - 12:25 pm: |
All alternators should put out between 14 and 14.4 volts with the car running. The diffrens is the # of amps they put out. |
| Posted on Thursday, January 06, 2005 - 10:53 pm: |
Well, I have a '97 Buick Park Avenue with a gauge info display and it says my battery is running 12.7v, very rarely will it hit 12.9 or 13. This kind of worries me cause I'm planning to get a kicker 400.1 and it will only push 400 rms if it receives 14v. So, is there a way I could run a solid 14v to the amp? |
Santa Monica,
CA
Post Number: 336 Registered: Nov-04
| Posted on Friday, January 07, 2005 - 01:44 pm: |
it's not going to receive 14V, that's a peak power rating. What kind of subs or speakers are you running with that amp? |
| Posted on Friday, January 07, 2005 - 04:05 pm: |
2 12" alpine s-type svc 4 ohm |
Santa Monica,
CA
Post Number: 338 Registered: Nov-04
| Posted on Friday, January 07, 2005 - 08:02 pm: |
That amp will drive those subs just fine, i promise  |
chris123456 Unregistered guest |
| Posted on Friday, January 07, 2005 - 08:23 pm: |
i have a few questions and i need some answers, if somebody wants to help me |
| Posted on Friday, January 07, 2005 - 08:36 pm: |
I have 2 audiobahn alum12Q's and a rockford p5002 amp, 1500 watts max, will that be ok for power |
| Posted on Friday, January 07, 2005 - 11:51 pm: |
Thanks Oleg Ni I'm gonna go ahead and get it. |
Santa Monica,
CA
Post Number: 339 Registered: Nov-04
| Posted on Monday, January 10, 2005 - 12:48 pm: |
Unfortunately, Chris, that will not be enough. 1 of those amps may be enough for 1 sub, but i'm not too sure. Those subs are pretty power hungry. |
| Posted on Thursday, January 13, 2005 - 10:55 pm: |
Just thought to let you know that I just finished installing my kicker 400.1 to my alpine type s's and it hits very hard. I got a question though. Is it necessary to get a cap with this kinda system? My lights don't dim out and my alt shoots out 105 amps. |
Santa Monica,
CA
Post Number: 344 Registered: Nov-04
| Posted on Friday, January 14, 2005 - 01:48 am: |
looks like you're good without a capacitor |
NorthWest,
Michigan
Post Number: 7332 Registered: Dec-03
| Posted on Friday, January 14, 2005 - 10:34 am: |
capacitors have nothing to do with dimming lights.
