Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2005 > In need of help for amp
Author Thread: In need of help for amp
taison
im thinking of purchasing either the 12 inch kicker L7s or the 12 inch w6v2 I need an amp to rock these subs.I was thinking about the mtx1501d amp wat do u guys think thanks alot
Username: Hdubb
Farmington, Nm
Usa
Post Number: 249
depends on the impedence of the drivers. this amp is only 2 ohm stable so if you decide on this amp make sure you get your subs in a dual 4 ohm load, so it will wire down to 2 ohms. i saw your post in subs,about which one and that depends on what you want. the l7s will be loud but not sound that good. the w6v2s will sound better but still deliver some punch. the l7s have quite often been know to just stop working. hope this helps
taison
yes thanks alot but will this amp have enough power for these subs
Username: Hdubb
Farmington, Nm
Usa
Post Number: 251
yes it would be enough power.
Username: Taylor17
Kopperl, Texas
Get the mtx with the Jl subs
Username: Oleg
Santa Monica, CA
Post Number: 327
If you're getting 1 w6v2, then mtx is fine. If you're getting 2, then you'll have to wire them in series-parallel to get a 4ohm load. I recommend just paralleling the coils and getting 2 MTX 801D amps, one for each sub...perfect set up. Or 2 kicker 400.1. Those run just under $200 shipped on eBay.
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2005 > In need of help for amp [ « Previous ] [ Next » ]
