Thread: Amp goes on and off. |
| Posted on Tuesday, January 04, 2005 - 01:18 pm: |
Im not sure why but the 520 watt amp I have that used to work fine now just turns on and off around every3 3-4 seconds. You can hear a tiny bit of music fo the second that its on for. Then it just turns off again. If any one knowswhy, or how I can cure this problem please let me know. Thankz. |
Bronze Member Username: Azdave
Post Number: 12 Registered: Dec-04
| Posted on Tuesday, January 04, 2005 - 02:03 pm: |
What is the ohm load that your speakers are presenting to the amp? What amp is it? |
| Posted on Tuesday, January 04, 2005 - 02:32 pm: |
Im not sure what the load is, but its connected to 2 5x9's an a 12 inch sub. Its a 4-channel, 520 watt amp. |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 337 Registered: Jun-04
| Posted on Tuesday, January 04, 2005 - 03:59 pm: |
Check your conections, especially your ground. Sounds like you may have something loose. |
Bronze Member Username: Wojopro
Post Number: 100 Registered: Nov-04
| Posted on Tuesday, January 04, 2005 - 11:58 pm: |
Sounds possibly like a grounded remote wire... The wire may be rubbing on metal somewhere... Just something to check. |
