Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > Right side output doesnt work HELP
Author Thread: Right side output doesnt work HELP
Username: Xxkmfdmxx
Saint Petersburg, FL
Post Number: 154
I recently bought a Power Acoustik amp which works quite decent but I can only put my speakers/subs on the Left output on the amp, When I try to put them on right side aswell I get no sound from that side. Checked the RCAS and they seem to be fine. What could be the problem?
Username: Hdubb
Farmington, Nm
Usa
Post Number: 195
are your rcas close to your power wire? that may be the problem. try moving them away from the power wire
Username: Xxkmfdmxx
Post Number: 155
Well, I have the power wire wired up on the opposite side of the RCAs so that should be fine.
Username: Hdubb
Farmington, Nm
Usa
Post Number: 200
then its probably the amp...they are kniwn to do things like that. which amp is it? i dont know what else it could be
Username: Xxkmfdmxx
Post Number: 156
The amp is a POWER ACOUSTIK OV2-520. Im gonna just try to get a refund from where I got it from since I just bought a MTX 311D to power my subs.
Username: Hdubb
Farmington, Nm
Usa
Post Number: 206
ya i melted a wire terminal on my pa lt980/2 good fun.
Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > Right side output doesnt work HELP [ « Previous ] [ Next » ]
