Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2005 > Glass or anyone else problem with fos...
Author Thread: Glass or anyone else problem with fosgate amp
2 poor
I have a Old rockford fosgate series 1 4060x 4 channel amp and one 12" sub DVC i would like to know how to put all the 4channels to the sub so it can hit harder Right know i got it bridged on the front channels how would i put the rear channel power to the sub? it has 4 rca inputs The only thing i know about this amp is that i'ts 2x 180 At 4 0hms any help would be apreciated.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7104
IF the sub has teo 4 ohm coils, bridge the amp to 2 channels and put one channel on each coil of the sub.
that'll put full power to the single sub
Username: Iamduff_87
Michigan
America!
Post Number: 320
wow.haha thats alot of channels for one sub. works but wierd.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7132
oopps I meant "two 4 ohm coils"
typo.
2 poor
hey glass i just connected the sub to the amp like you said and all you hear is disortion. I dont know if i connected it wrong but it sounded bad. If you have the time can you maybe post a picture of how i'ts supposed to be connected i just want my sub to be a liitle better until I upgrade. Thanks
Username: Glasswolf
NorthWest, Michigan
Post Number: 7180
the amp's manual should show how to bridge it.
you have it wired wrong if all you're getting is distortion though.
http://www.bcae1.com/bridging.htm
that explains how bridging works
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2005 > Glass or anyone else problem with fos... [ « Previous ] [ Next » ]
