Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > Tell me how you like my setup ( Glass...
Author Thread: Tell me how you like my setup ( Glasswolf and others)
Username: Bigap15
Post Number: 53
Ok, im getting a soundstream Van gogh vga600.2 to push 2 Alpine type r 10" subs. The subs are 300 watts rms each and the amp puts out 300 x 2 @ 2ohm rms. So they match fine. The subs will be in a sealed 1 cubic foot box per sub. The cd player i will be getting is a Alpine CDA-9827. Tell me if this is a good setup. I will also be upgrading hte alternator. I will be using a 4 guage power kit. need recommendations on which 4 guage kit to get. Thanx
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 120
sounds nice. I use stinger wires. they are fine.
Username: James1115
Ct
Post Number: 137
sounds good to me man!
Username: Glasswolf
NorthWest, Michigan
Post Number: 7093
www.knukonceptz.com has good amp wiring kits, and pretty affordable, too.
rest sounds fine.
Username: Killerbuffalo
Post Number: 10
So are amp wiring kits only for the amp or also speakers? I was looking at the 4gauge complete amp wiring kit from the above link but if I get that do I also need to get other wires to connect 2 subs to the amp?
Username: Drumjunky
Boulder, Colorado
Post Number: 23
I got the 4 gauge kit from KnuKonceptz and it comes with almost everything you'll need.
4AWG power wire
4AWG ground
RCA cables (HU to amp)
12AWG speaker wire (12AWG)
fuses and terminals
all I had to pick up was a couple extra terminals and another fuse (mine came broke)
I think it's a great wire kit and had no problems so far...and you cant beat(i don't think)the price! (~$38 shipped)
...some good quality stuff
Username: Glasswolf
NorthWest, Michigan
Post Number: 7122
their kits include the speaker wire, a fuse, and connectors.
when I ordered mine, they generally have what I need unless I want distribution blocks to split to multiple amps. All I order separately are additional fuses in the specific size I need for a given system. I try to match my fuse ratings to the peak continuous current draw of the system when I wire it all up, just to keep tolerances tight.
Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > Tell me how you like my setup ( Glass... [ « Previous ] [ Next » ]
