Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > comparing 2 amps
Author Thread: comparing 2 amps
Username: 70el_co
Fort walton beach, Florida
U.s.a
Post Number: 10
According to the comparison of thses specs what would be the best amp for an infinity refernce 6000cs component system. Thats the 2 xovers, 2 tweets, and 2 6.5 mids (90rms @ 4 ohms).
infinity 7520a Performance
RMS Power Output (Watts x Channels) 97 x2 @4 ohms
Frequency Response 20-20k Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 83 dB
Input Voltage 14.4v
Peak Power Output (Watts x Channels) N/A
Power at 2 Ohms (Watts x Channels) 142 x 2
Bridged Power (Watts x Channels) 283 x 1
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Features
Amplifier Class AB
Tri-Way Capable Yes
Low-Pass Crossover Frequency 32-320 Hz
Low-Pass Slope (dB/octave) 12 dB
High-Pass Crossover Frequency 32-320 Hz
High-Pass Slope (dB/octave) 12 dB
Bass Boost 0-12 dB
Bass Boost Frequency 50 Hz
Fan Cooled No
Fuse Rating 30 x 1
Speaker Level Inputs Yes
Preamp Outputs 1 pair
LED Power Indicator Yes
audiobanh 4002t Performance
RMS Power Output (Watts x Channels) 100 x2 @4ohm
Frequency Response N/A
THD at Rated RMS Power 0.02%
Signal to Noise Ratio 100 dB
Input Voltage 12.5v 12.5v
Power at 2 Ohms (Watts x Channels) 200 x 2
Bridged Power (Watts x Channels) 400 x 1
Features
Amplifier Class AB
Tri-Way Capable Yes
Low-Pass Crossover Frequency 50-120Hz
Low-Pass Slope (dB/octave) 18dB
High-Pass Crossover Frequency 50-750Hz
High-Pass Slope (dB/octave) 18dB
Bass Boost +18dB
Bass Boost Frequency 50Hz
Fan Cooled Yes
Fuse Rating 40 x 1
Preamp Outputs 1 pair 1 pair
LED Power Indicator Yes Blue
Ready to buy an amp. Just waiting for some sound advise from people that know way more than me. Would appreciate the input, Thanks.
Username: Iamduff_87
Michigan
America!
Post Number: 311
I would probably go with the infinity. how much have you priced these as? i might look at alpine/mtx/kicker/jl/eclipse first. Then maybe Rockford or Phoenix Gold
Username: 70el_co
U.s.a
Post Number: 11
the infinity is $155 and audiobahn at $130
i'll check them out
Username: 70el_co
U.s.a
Post Number: 12
i'll check them out
Username: Glasswolf
NorthWest, Michigan
Post Number: 7063
the infinity is a better amplifier.
Michigan
America!
Post Number: 322
Kicker KX200.4 $130 new on ebay. 100watts x 2 @ 4 ohms. good amp. looking into buying one myself maybe.
Username: 70el_co
U.s.a
Post Number: 13
thanx for a the help im still comparing other amps, but i'm really leaning towards that kicker 200.4. whats the difference in sound quality between getting a 2 channel amp or getting a 4 channel amp and bridging them for 2 mono channels ?
Michigan
America!
Post Number: 326
none. they are both ab class amps. the sound quality will come from the brand and the wiring(rca cables) and HU and speakers.
Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > comparing 2 amps [ « Previous ] [ Next » ]
