Thread: Good or not |
New member Username: Marley289
Post Number: 4 Registered: Nov-04
| Posted on Friday, December 31, 2004 - 11:44 am: |
i was looking at a boss audio amplifier. its 1500 watts and i just wanted to know if it would be any good or do they overrate thier stuff. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14254 |
taylor17 Unregistered guest |
| Posted on Friday, December 31, 2004 - 11:47 am: |
Sory Boss is really bad. Not the worst but not grate by any means. |
Post Number: 5 Registered: Nov-04
| Posted on Friday, December 31, 2004 - 11:53 am: |
why is it bad whats wrong with it? |
| Posted on Friday, December 31, 2004 - 12:07 pm: |
Boss just isn't grate quallity, or that grate at reliability. |
| Posted on Friday, December 31, 2004 - 12:15 pm: |
Also that amp is an 800 watt amp. The 1500 watt's is a max output, max mean's virtually nothing. At 2 ohms that amp will put out 800 watt's rms. Rms means basically "constant" power. |
NorthWest,
Michigan
Post Number: 7058 Registered: Dec-03
| Posted on Friday, December 31, 2004 - 12:24 pm: |
RMS power, 4 ohm: 540w x 1 RMS power, 2 ohm: 800w x 1 for $180 I can find much nicer amplifiers. BOSS Audio amps are built with cheap, low quality components and poor designs. I've seen a lot of them fail for no good reason within a year or so of purchase. The only saving grace is a long warranty so you can send it back to them repeatedly for replacement when it does fail for some of their models. This one doesn't even appear to have the normal 5 years though.. only 1 year. It's a matter of getting what you pay for. If you want 800 watts RMS, you'll have a hard time finding that large amount of power in a reliable package for as cheaply as you're shopping. If you want a good amp, save up some money and buy something worth the money you're worked to earn.
