Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > Problem...
Author Thread: Problem...
Username: Smhuosrktays
Rochester, New York
Post Number: 33
Ok, my rear speaker are hooked up to my amp, and they make a crackling noise only when they're hooked up to the amp. I have a clean ground connection, anyone know what could cause the crackling noise?
Username: Vaio
The amp have too MUCH bass. Turn your bass down.
Username: Carguy
Post Number: 969
When you start hearing crackling noises at high volume, it's a good sign you're getting close to the speaker's limit. I would suggest you turn down the volume a bit till it's gone.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7023
also consider adding a high-pass filter as a bass blocker to stop the speakers from bottoming out.
Rochester, New York
Post Number: 34
This is an amp for regular speakers, not subs, I dont have the bass turned up at all. The crackling happens at all volumes. The amp has a hpf on it. Any other ideas?
Username: Glasswolf
NorthWest, Michigan
Post Number: 7044
bad amp ground
speaker grounding out to bare metal at one of the terminals
pinched RCA cable
RCA signal lines and power lines running side by side
I got lots of ideas!
Username: James1115
Ct
Post Number: 127
the speaker could be fried!
James
Rochester, New York
Post Number: 35
the amp ground is fine, i know that.
it could be pinched rca's(highly unlikely though)
the rca's are running the opposite side of the power line
speakers aren't fried, nor the amp, the speakers work fine when the amp isnt hooked up to them, its just that they crackle when it is.
Username: James1115
Ct
Post Number: 130
ohhh ok they work fine off the deck? I understood you wrong. try hooking that amp up to other speakers and if you get the same result then it is the amp. I had an amp that picked up engine noise it was the wierdest thing and I thought it was the install but after walking through and eliminating every other option I found out it was the amp so I changed it and whala it worked fine. so try that.
James
Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > Problem... [ « Previous ] [ Next » ]
