Thread: Multi amp to single sub |
Unregistered guest |
| Posted on Wednesday, December 29, 2004 - 02:36 am: |
I just picked up a Power Acoustik MOFO and want to hook up both my PA OV2 1600's to it is that posible? I know the sub is dual 2ohm .....some one PLEASE HELP |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 292 Registered: Nov-04
| Posted on Wednesday, December 29, 2004 - 01:37 pm: |
i don't think those amps are capable of that |
PowerProblem Unregistered guest |
| Posted on Wednesday, December 29, 2004 - 08:07 pm: |
that sucks do you know of any amps that can i need to find a way to push 1500 watt RMS and 2600 peek
Santa Monica,
CA
Post Number: 306 Registered: Nov-04
| Posted on Thursday, December 30, 2004 - 01:03 am: |
how much money can you spend? |
New member Username: Vermontspl
Randolph ,
Vermont
Post Number: 1 Registered: Dec-04
| Posted on Thursday, December 30, 2004 - 10:02 am: |
I'm goin for some high SPL i want to put a total of 3 of the MOFO's in. so i know the money is gonna add up. The amps i have now cost me about $140 a piece...i got conections. but i'll have to get 6 if i multi amp. if you know a better way or even with the price range through it out i'm open to basicly anything |
| Posted on Thursday, December 30, 2004 - 10:53 am: |
Matt ward, try taking a look at this http://www.sonicelectronix.com/viewitem.php?id=2796 it an Alphasonik PMA1000HCA with 6000W max and RMS Power Rating: 900 watts x 2 chan. at 2 Ohms Stereo which you could brigde to one speaker for like 1800w rms. and its only around like $369.99 so you could get two of them. 739.98$ USD |
Randolph ,
Vermont
Post Number: 4 Registered: Dec-04
| Posted on Thursday, December 30, 2004 - 11:08 am: |
thanks A.C. that looks trinck i'll check it out |
Randolph ,
Vermont
Post Number: 5 Registered: Dec-04
| Posted on Thursday, December 30, 2004 - 11:09 am: |
ya like i can spell *trick* |
Santa Monica,
CA
Post Number: 311 Registered: Nov-04
| Posted on Thursday, December 30, 2004 - 11:35 am: |
I'm not sure if those subs will last in SPL applications, but you can give it a try. $140 for those amps is hardly having connections Here're some choices for you to power all 3 subs: 1. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64572%26item%3D5739807157 %26 2. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5741024625 %26 3. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5739706934 %26%26 4. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=79829%26item%3D5741069487 %26 I would go with the rockford though, it should push 3 of them very well. |
