Thread: Phoenix Gold Amp |
foxstoner0420 Unregistered guest |
| Posted on Wednesday, December 29, 2004 - 12:15 am: |
Will this amp really do 400 w RMS x 2 @4 ohms. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4950%26item%3D5740686360% 26%26 |
Bronze Member Username: James1115
Ct
Post Number: 95 Registered: Dec-04
| Posted on Wednesday, December 29, 2004 - 12:57 am: |
most likely phoenix gold is pretty good stuff! |
Silver Member Username: Djeter108
IN
Post Number: 106 Registered: Nov-04
| Posted on Wednesday, December 29, 2004 - 03:54 am: |
i heard phoenix gold is terrible |
Silver Member Username: Zacdavis~
Post Number: 413 Registered: Sep-04
| Posted on Wednesday, December 29, 2004 - 04:11 am: |
phoenix gold has always been top of the line. you heard wrong my friend. but they did recently start a line of products that is more affordable than thier top lines. |
Ct
Post Number: 100 Registered: Dec-04
| Posted on Wednesday, December 29, 2004 - 04:02 pm: |
yeah I would never consider them horrible or even bad they are not the Best you can get but they are good! always have been! |
Post Number: 416 Registered: Sep-04
| Posted on Wednesday, December 29, 2004 - 05:28 pm: |
actually they "are" considered the best you can buy by many people. i remember a time when phoenix gold ms were the baddest amp period. |
| Posted on Wednesday, December 29, 2004 - 06:17 pm: |
So do you think this amp is over rated or is it really 400 w x 2? |
Post Number: 417 Registered: Sep-04
| Posted on Wednesday, December 29, 2004 - 11:03 pm: |
typically you wouldnt buy a 4ch amp for subs anyways. i wouldnt recomend this amp for any woofers, wether or not its is capable of producing enough watts for subs is not the issue, the fact that it has 4 channels is. go with a two channel or mono block. thats my opinion. secondly, i mentioned that phoenix gold now offers a lower more affordable line, that amp you linked is one of that line. heres the deal with phoenix gold... if you think the price is affordable, then it is thier lower quality product if you think wow the price is way too expensive... then your looking at some of thier top quality products (phoenix's good stuff is very expensive, the link you gave up there is for some of the crap they decided to make to commercialize thier company) |
Silver Member Username: James1115
Ct
Post Number: 115 Registered: Dec-04
| Posted on Wednesday, December 29, 2004 - 11:13 pm: |
your right Zac I knew that back in the day they were top of the line. I didnt know if they were bought out by anyone else in the last few years. Remember that $100,000 amp they had at one point? man that was sick. Well back to the topic Just make sure the amp you are looking at isnt their low end line, but even their lower end line is better than alot of amps that I see people using around here. Well thats my opinion. James |
