Thread: Place for a big amp |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 264 Registered: Nov-04
| Posted on Tuesday, December 28, 2004 - 10:50 am: |
I'm concerned about my amp being attached to the top of my sub box, i know vibrations are bad for it. I can't find a place to put it though. It's about 26" long, any thoughts? Back of my seat is not big enough and already has another amp on it. |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 295 Registered: Jun-04
| Posted on Tuesday, December 28, 2004 - 11:54 am: |
If your box is well built and mounted properly their shouldn't be a problem. You can even use a rubber spacer between the amp and the box to dampen the viberations a little more. All in all your box shouldn't flex or vibrate much anyways. If it does you really need some more bracing. |
NorthWest,
Michigan
Post Number: 6969 Registered: Dec-03
| Posted on Tuesday, December 28, 2004 - 12:07 pm: |
you could do a false floor in the car and flush mount the amplifiers there in front of the sub box. it'd keep the trunk usable, and make the amps look nice, concealing all the wiring at the same time. like this: http://www.wickedcases.com/caraudio/nakamichi-RF_01b.jpg
Santa Monica,
CA
Post Number: 277 Registered: Nov-04
| Posted on Tuesday, December 28, 2004 - 01:01 pm: |
so i see that you got another panel of some sort? what is that called and where do i get it? |
NorthWest,
Michigan
Post Number: 6989 Registered: Dec-03
| Posted on Tuesday, December 28, 2004 - 01:05 pm: |
you make it. use plywood and carpet it using stand-offs to raise the platform to the desired height. cut openings where you need them for the amp(s). pretty simple concept.
Santa Monica,
CA
Post Number: 278 Registered: Nov-04
| Posted on Tuesday, December 28, 2004 - 01:29 pm: |
my box is urethane coated. www.proboxrocks.com it's the superbass for 2 10" |
New member Username: Legitdank
Mayfield Hts,
Ohio
United states
Post Number: 10 Registered: Dec-04
| Posted on Tuesday, December 28, 2004 - 01:33 pm: |
yooo, can you guys help me with my stuff when you get a moment? ~ AMP settings~ |
