Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > Orion 3002 2channel good or bad? HELP...
Author Thread: Orion 3002 2channel good or bad? HELP!!! ASAP PLZ.
Username: Narayana
Post Number: 13
Looking to buy this amp on ebay, brand new, planning on hooking it up to 2 kicker comp 150 watt subs. this work good? if not what's good subs to hook this up to for around $100?
thanks
~narayana
Username: Killer44
Niagara Falls, Ontario
Post Number: 12
try power acoustik...
OV2-520...150x2 @2 ohms...
www.poweracoustik.com
Username: James1115
Ct
Post Number: 108
that orion amp is alot better than a power acoustic! just to let you know so if you plan on doing better subs in the future that amp will be a better amp to have!
James
Home > Message Board > Car Audio > Amplifiers > Archive through January 04, 2005 > Orion 3002 2channel good or bad? HELP... [ « Previous ] [ Next » ]
